Home > V8 > GM L83 vs L86
johnnyha
1996 Defender 90 300 Tdi CSW Epsom Green
GM L83 vs L86
Just wondering why the former isn't more frequently used as a conversion engine, given the likely improved fuel efficiency, and less need for drivetrain hardening.
Any views from anyone who's considered this appreciated
Post #943266 21st Feb 2022 11:25am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
Good question, the L83 is still right on the limit of the LR drivetrain, perhaps even past it without some serious upgrades. I suspect at that point the L86 is more appealing if you're already having to go down the route of swapping the gearbox etc. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #943334 21st Feb 2022 6:42pm
Pickles
Can't see the point in going L83 if one is going to go to all the trouble & expense with respect to a conversion via the GM V8 route.
L86 gives greater capacity, much more powere etc, and indeed there are probably other engines of similar capacity in the GM stable that are even better.
IMHO the 6.2L LS3 is the ideal engine if you're going to be naturally aspirated,and if you're considering supercharging, well there's a range of GM engines to choose from.
There are so many engines to choose from, I can't remember them all, but a google search of say "GM Crate engines" would be a start.
As we used to say, "There's no substitute for cubic inches", the later words being "There's no replacement for displacement"!
Of course these are just my thoughts, because at the end of the day, it's absolutely your dollars & your choice.
Pickles.
Post #943381 21st Feb 2022 9:46pm
