Home > Td5 > Fuel gauge swings
Goldenballs
Fuel gauge swings
Hello!
My fuel gauge drops quite significantly when turning right. Ordinary I’d say this is “normal” due to the fuel motion in the tank, but I don’t think I’ve noticed it before. Does this mean my fuel pump / sender is on the way out?
Post #942907 18th Feb 2022 12:44am
Dinnu
Does your speedometer works? This behavior also happens when the speedo is disconnected from the transducer. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #942910 18th Feb 2022 6:50am
Goldenballs
You’re correct! How on Earth are they linked?
Post #943181 20th Feb 2022 5:50pm
^^^^ because the fuel guage "damping" circuitry is built into the speedo itself
Mine went wrong some time back, so when the fuel level got to about 3/4 tank the guage would drop down to not much. I bypassed the speedo wiring so the guage runs directly off of the sender unit now.
OK when you drive along it flips around like an old series 2 guage, but at least its accurate. Might try and graft in a Series 3 damper unit if I can find one.
Post #943226 21st Feb 2022 7:57am
