Home > Off Topic > Experience of using a Hi-Lift Off-Road Kit |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2630 |
The chain is best.
When using the Hi Lift as a short pull winch, as you say useful for clearing large branches out of the way, the chain won’t stretch. There is not much in the way of pull with a four foot jack without having to reset it, so what you don’t want is a foot and a half of potential stretch. The chain it talks of with the two hooks will lock onto itself so that you can easily adjust the overall working length. The strap is best when wrapping around a tree to save the bark and the tree itself. Hope that helps. |
11th Feb 2022 3:06pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Just bear with me on this, as it's hard to get my head round and put in writing...
I think the chain I need is to allow me to reset the jack under tension and needs to be slightly longer than the full travel of the jack (4ft in my case). From reading the instructions and watching the very poor HiLift video, I don't believe its possible to reset the jack under tension when using just recovery straps with ORK as the holding chain that comes in the kit would have nothing to grab to take the tension. You can't hook it half way along a strap. Does that make sense and sound right? If that's the case, where might I get a suitable length of chain with hooks? 2007 110 TDCi Station Wagon XS |
11th Feb 2022 3:15pm |
