Home > Faults & Fixes (L663) > Steering off centre. Anyone else? |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
Funnily enough we have had our 110 XS for 2 weeks and I’ve noticed the same issue. Looks to me that the steering wheel has been fitted 1 or w splines off 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
10th Feb 2022 11:21pm |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 284 |
This isn't a wheel alignment or tracking issue, the workshop just needs to re-centre the steering by adjusting the track rod ends.
11th Feb 2022 7:20am |
BlueSmoke Member Since: 27 Apr 2021 Location: Kent Posts: 12 |
I thought this could be the case rather than tracking. I was convincing myself it was easier to turn right than left but that could have been in my head. Thanks very much.
11th Feb 2022 7:59am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2780 |
This is quite common with new cars, our Jimny steering wheel is very slightly off centre when driving in a straight road.
lt used to annoy the hell out of me as well, but l've given up stressing about it now. It needs a very slight adjustment of both track rod ends, as stated above. One has to go in, the other out, by about 1/5 of a turn on the threads. lt's a little bit of trial and error, it's easy to adjust too far and end up with the steering wheel slightly off centre the other way, and have to adjust again! Best to mark the "before" settings with white paint. |
11th Feb 2022 8:16am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17388 |
In the "good old days" this is the sort of thing which would be picked up and corrected during the Pre-Delivery-Inspection or PDI process. Disappointing that it isn't.
As Nuclear Nick says it is remedied by adjusting the TREs, one in and the other out by equal small amounts, on vehicles with rack-and-pinion steering (for the old Def it would be similar but it would be the drag link which would be lengthened or shortened). Moving the steering wheel would have a massive effect. I don't know how many splines there are on the new Def steering column, but an old Def is 36 or 48 depending on various largely random factors, so moving the wheel one spline would shift it either 10 or 7.5 degrees, which is far more than the OP's misalignment. |
11th Feb 2022 9:10am |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 661 |
My VW T5 is pretty susceptible to road camber. So normally left hand down.
11th Feb 2022 9:54am |
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 |
Yep same on mine slightly off to the right, I’m just living with it…. LR quirk…. L663 90ht
5th Mar 2022 11:16am |
Mine is also slightly off to the right, l think it happens as the new suspension components settle, as it was fine when l got it.
Our Suzuki Jimny also did the same thing. I've never bothered adjusting the Jimny steering as my missus hasn't even noticed it, but l'll adjust the Defender after l've done a couple thousand more miles. |
1st Dec 2022 6:16pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3396 |
My 90 was fine, but definitely noticeable on my 110. 24MY 90 D250 HSE, Tasman Blue
1st Dec 2022 8:37pm |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 132 |
Should track true, simply "living with it" is not good enough on these high end modern vehicles. get a proper wheel alignment done. Note the dealers don't do it themselves, they usually farm this out, the trick is to find a shop that knows what they are doing. The EAS doesn't make it easy, as the car is continually trying to level. It needs to be put into tight tolerance mode before doing any alignment work, otherwise it's all for nought.
9th Oct 2023 12:32am |
l've had my Defender 90 for ten months now and the steering wheel does appear to be very slightly off centre to the right when driving in a straight line. However it depends on road camber. lf l drive on the opposite side of the road the steering wheel centres slightly to the left.
14th Oct 2023 2:03pm |
