Home > Puma (Tdci) > DPF Regen VERY often
CalumD23
United Kingdom 2013 Defender 90 Puma 2.2 HT Tamar Blue
2013 Defender 90 Hardtop 2.2 TDCI
I’m concerned I may have a DPF problem - does this sound normal?
I drive around 1 mile to and from work (2 miles total) every week day, and occasionally I won’t use the car on the weekend if I’m elsewhere.
When doing these daily trips with no driving on the weekend, I find my orange DPF light comes on after about 2 weeks (so around 20 miles of driving over 2 weeks). Last week I didn’t have the time to take it for a longer drive to regen it so I left it. A few days later, the red DPF light comes on, followed by the check engine light.
Today I took it for a 20 minute drive to regen the DPF, then reset the warning lights - it seems to be back to normal.
Does this sound normal, because I do very short journeys daily? Or do I maybe have a DPF problem and need to give it a clean?
Post #942003 10th Feb 2022 8:59pm
Caterham
I don't know but it certainly doesn't surprise me with such short journeys.
Post #942013 10th Feb 2022 9:52pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Vehicles with DPF’s need to be used regularly getting the vehicle up to full working temperature with some longer trips for the DPF to work and self clean efficiently. (DPF regen)
I remember when DPF’s first came out people living in the channel island were having all sorts of problems as some islands were only a few miles long meaning a DPF would never work.
I specifically bought the 2.4 because it didn’t have a DPF, have you considered getting it removed? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #942033 11th Feb 2022 7:40am
Matt110
With a 1 mile commute, all you will ever do is progressively fill the DPF up. So whenever you then do anything any longer than that - it will attempt to regen 100% of the time as long as conditions allow.
Sadly there's not much you can do about this. Your drive cycle isn't OK with a modern diesel, it'll constantly fill up and eventually throw up a code with a full up DPF. All you can do is either do a commanded static regen every now and again, which is smelly, noisy, and rather pointless as you could be enjoying driving it somewhere to achieve the same thing..... or, every few days drive for long enough that you hear the injector note change and it doing it's regen, and then critically.... STOP doing a regen, i.e. the injector sound returns to normal.
If you get it again having changed drive cycle and started driving further more often, then you'll potentially need to do that static commanded regen to get to a low soot loading, and try again.
Post #942035 11th Feb 2022 7:46am
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
My 2013 averages around 130 miles between regens for short journeys. By short I mean under around 20 miles. When travelling longer distances I can get over 200 miles between regens. I’ve 90k on the clock so presume there must be a build up of ash reducing dpf performance. I use a scanguage to tell me how full the dpf is. I’ve never had the dpf led light up, but I can see how you could reach that point with such very short journeys.
Post #942080 11th Feb 2022 5:10pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: DPF Regen VERY often
That's why taxi drivers said good-bye to their diesel engines.
Just look inside your user manual : you need service temperature and a ride on a highway for quite some time in order to get your DPF cleaned.
We're not often on short daily commuter trips - most of our rides take 1h or even much much more.
No DPF issues so far - the last MOT ended up with 3x 0.00 particulate matter. They didn't believe Shocked
Post #942107 11th Feb 2022 8:55pm
Roy5695
Surely a one mile journey each way wouldn’t warrant driving?
I’d walk.
Plus you won’t be burning in-necessary diesel doing a regen every 20 miles.
On my 2.2, 15miles each way, so 30 miles a day, I’d see one regen every full tank or so. So about 400miles in the 110 (70litre tank) 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #942123 11th Feb 2022 11:39pm
lakelander
United Kingdom 2013 Defender 90 Puma 2.2 CSW Orkney Grey
I do low mileage in my 2013 2.2 with DPF, but try to do a regular decent run on my A road. ( 20 miles ).
Never experienced a problem but can't say I've noticed a regen.
What are the signs of it taking place ?
Post #942145 12th Feb 2022 10:19am
Balvaig
I have tried to attach the workshop pages which explain regeneration.
Post #942149 12th Feb 2022 10:56am
lakelander
Interesting.
Fortunately all must be working well in mind .
Thank you for the comprehension information
Post #942156 12th Feb 2022 11:33am
CalumD23
Thanks guys - interesting stuff. The 1 mile commutes are about to cease and I'll be using the wagon properly again soon; good to know that I don't have a problem and it's to be expected with short journeys.
Post #942164 12th Feb 2022 12:31pm
Balvaig
Don’t ignore the orange DPF light. You can run into all sorts of expensive problems if you get the red light.
Forced regens are not good. Try for a longer run at about 50 mph minimum until regen occurs when you get the orange light.
Post #942170 12th Feb 2022 1:42pm
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Resurrecting this thread a bit. I watched my first dpf regen today but had no orange light etc. Been doing short journeys for 160 miles or so, then today I had a longer 50mph bit for 10 mins when the soot % went from 80 to 7 in a surprisingly short time.
Is it supposed to show the orange light every regen?
Post #950053 21st Apr 2022 9:52pm
Co1
I think it only shows the light if there is a problem. If it is just regenning routinely it won’t show the light, at least that’s the case in mine.
Post #950070 22nd Apr 2022 5:26am
Balvaig
Orange light does not show unless the system determines that there is a problem.
Normal regen just happens. You can sometimes tell by engine noise or smell.
Post #950076 22nd Apr 2022 7:02am
