Home > Maintenance & Modifications > Oil in Water Problem
Smifflie
England 2015 Defender 110 Puma 2.2 SW Santorini Black
Hi all, can you help me with a problem I have with an old Defender 90 (C reg) 200 TDI engine.
I had oil in the water but no water in the oil. Changed radiator/oil cooler combined, after flushing engine several times. Okay for a while, now same problem again. Any ideas? Do you think it is head gasket or the radiator again? Thanks for your help. Sad Big Cry
Post #941945 10th Feb 2022 1:17pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Head Gasket… Sounds like it and because your oil pressure is instant on start up it’s more common to have oil in water. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #941951 10th Feb 2022 1:50pm
Smifflie
Thank you for your reply. Looks like another mucky job on it's way. Whistle
Post #942053 11th Feb 2022 10:34am
Procta
Sounds like that's early signs of head gasket failure, My rover metro started going that way, when the headgasket started to fail. What may happen, when the car is up temp, you may start seeing thick steam coming out of the exhaust.
id jump on it before it gets worse, Check the head to see if its warped, Not sure if these do suffer from that. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #942265 13th Feb 2022 1:02am
Smifflie
Hmmm, my other half hasn't seen steam from the exhaust as yet but he's planning on getting the head skimmed as well as a replacement gasket. I remember having a Triumph Spitfire soft top sports car years ago where the flange gasket kept breaking down. Sounded like a piece of cardboard flapping in the spokes of a bicycle to start with and ending up more like a cement mixer on the go. Thanks for your reply, looks like it's going in one direction with this problem.
Post #942337 13th Feb 2022 4:57pm
Mo Murphy
You'll only get steam if the gasket breaches between a waterway and a cylinder. Oil in the water is indicative of a breach between waterway and oil way with regard to head gasket failure.
HTH
50 Shades of Pennine Grey
Post #942342 13th Feb 2022 5:22pm
jddisco200tdi
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I would also have a look at the radiator, as the engine oil cooling goes thru it. Regards
John D - Defender 110 2.4
Post #942395 14th Feb 2022 12:53am
Smifflie
Really appreciate all of your replies. I'm now off to speak to my favourite mechanic on Monday.
Post #943123 20th Feb 2022 8:24am
Leamreject
Good shout but you would see oil in the coolant and coolant in the oil normally if this were the fault, oil pressure is greater than coolant on start up and coolant pressure remains higher than oil pressure on a hot engine once turned off.
Still worth a check though as odd things happen Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #943133 20th Feb 2022 9:42am
