Home > Td5 > Part Number for TD5 pulley
JohnGr
Hi,
Can anyone confirm if the two pulleys marked in yellow are the same part number? I need to replace both, but Paddocks Spares were not able to say if they were!
Thanks.
Post #941428 7th Feb 2022 4:58pm
roel
I think they are the same.
Did you check here?: http://lrparts.ru/engl/ Roel
2003 90 Td5 (2009-now)
Post #941435 7th Feb 2022 5:38pm
JohnGr
Hi Roel,
Yes I looked at it but it's got the same diagram as I posted which doesn't show a part number. I think they possibly are the same, but just wanted to see if anyone could confirm. I can't believe that Paddocks couldn't tell me one way or the other. Thanks.
Post #941459 7th Feb 2022 6:28pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I don't think Paddock's would be able to tell you as they are a different part number as the one on the right comes with its aluminium bracket to bolt into where the ACE pump would go.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #941618 8th Feb 2022 12:29pm
derbywill
Just checked on Microcat and the pulley itself is a different part number, (when I purchased one it came with the bracket)
Part numbers are ERR6658 and ERR6493 (looks like it has a spacer and a longer bolt)
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #941620 8th Feb 2022 12:34pm
JohnGr
Hi Will,
Thanks for the info...
I've got them both off and they have the same bearing number on both of them 6303 LHA.... they look identical, but the one to the left has a spacer to space it out, but it comes off (ERR @ £29.69). I don't need the bracket for the one on the right, but I can buy just the pulley (ERR6658 @ £‌45.44) I'm assuming the one to the right encased in yellow must be a stronger bearing as it looks to me like it would be under more strain, hence the extra cost??
Thanks
Post #941637 8th Feb 2022 1:37pm
rallysteve
I changed the bearings in both of those pulleys on mine and the bearings were identical. I didnt compare the two pulleys in detail but believe they are both the same.
Post #941642 8th Feb 2022 1:50pm
JohnGr
Thanks Steve,
I can't see any difference between the two either, but makes you wonder why the one without the spacer is more expensive!
Post #941643 8th Feb 2022 2:02pm
derbywill
I’ve always found it strange how one part is £x but a slightly different part is so much more, especially on things like this when it appears it’s a bolt and spacer what is the difference.
Will 2005 90 XS
1968 88” 2A 200tdi
2002 110 Hardtop
Post #941711 8th Feb 2022 8:32pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
JohnGr wrote:
Thanks Steve,
Because they have to remove the bolt and spacer Rolling with laughter 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #941844 9th Feb 2022 8:48pm
