Home > Maintenance & Modifications > Which grease gun? |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 841 |
Morning all.
Could someone point me in the direction for a good grease gun that has a good length flexi to reach all the areas. Would this suffice? https://www.screwfix.com/p/hilka-pro-craft..._container Cheers 2008 2.4 110 Utility Station Wagon XS. |
7th Feb 2022 8:16am |
I did have a quick search - there just doesn’t seem to be a ‘go to’ gun that everyone agrees on, from what I’ve seen. 2008 2.4 110 Utility Station Wagon XS.
7th Feb 2022 10:47am |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
I use this one.
https://www.machinemart.co.uk/p/clarke-cat-125-air-grease-gun/ It takes grease cartridges which are less messy than loading from a tub. |
7th Feb 2022 10:58am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
Some grease nipples on the puma UJ are so difficult to grease. Their location on the center of the cross, with an angled nipple makes it impossible to reach with a normal grease gun. I think the one next to handbrake drum is the worse.
Never had problems with my old 90, with grease nipples on the side of the cross. Not much (if anything) else to grease. My puma does not have grease points on the prop shaft splines. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
7th Feb 2022 11:10am |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 825 |
I just got the one thats the pistol type from Gwyn Lewis, upgrade from my previous one that you need 3 hands to operate. I brought the extension tube for the gun also and did all my prop nipples with no issues on the puma last weekend. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
7th Feb 2022 1:06pm |
Thanks for the replies
I have looked at the Gwynn Lewis ones. If you’ve used it on the Puma type, then I may just give that one a go Cheers 2008 2.4 110 Utility Station Wagon XS. |
7th Feb 2022 1:19pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4218 |
I improved my Laser gun no end by fitting a flexi hose with Lock-n-lube coupler. 2007 110 TDCi Station Wagon XS
7th Feb 2022 1:43pm |
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 |
Ive had three and my favorite one is this one handed jobby.
https://www.biltema.no/en-no/car---mc/car-...2000022145 I also use one of these quick connect thingys: https://www.biltema.no/en-no/tools/compres...2000041997 this makes it easier as I find the regular guns need two hand to hold and pump, and a third hand to hold the grease nipple connection. I have given up trying to grease them in place - you really need to disconnect one end to do the job properly by moving the joint around. Roaming around 🇳🇴🇨🇭 |
7th Feb 2022 2:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17467 |
With pleasure: Milwaukee M18 greasegun. You omitted one rather crucial piece of information - your budget! |
7th Feb 2022 6:23pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20479 |
I’m really happy still with my Allemite 500-E with narrow lock n’ lube coupler.
Does everything I want really well. If I had a lot of use for other things I’d definitely consider the Milwaukee 18v for sure. Nice bit of kit, you get what you pay for. I spotted a nice tool the other day https://www.ebay.co.uk/itm/395406666611?_t...p_homepage Just the design caught my eye, Ltd edition as well. Wera Joker spanner’s are nice too. Though straying off topic slightly here and thread revival. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Jul 2024 7:42pm |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 |
Messy to fill but love mine...
https://www.ebay.co.uk/itm/256558813602?mk...media=COPY |
6th Jul 2024 9:12am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
This was recommended by a fellow Defender2 member. Had it a couple of years - absolutely spot on.
https://www.fuchs.com/de/en/product/produc...REASE-GUN/ Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
6th Jul 2024 12:31pm |
Ianb Member Since: 25 Oct 2023 Location: Devon Posts: 410 |
Makes me chuckle how this topic started 2 years ago and everyones example is different
I use the typical style of grease gun, but the one I bought had a fixed angled nozzle and was impossible, got a flexi from machinemart and was good to go The Yeti - 110 Camper https://www.defender2.net/forum/topic90308.html Youtube - https://www.youtube.com/@YetitheDefender Instagram - https://www.instagram.com/yetithedefender/ |
6th Jul 2024 1:46pm |
This is the best manual grease gun I have met in recent years. |
6th Jul 2024 9:00pm |
