Home > General & Technical (L663) > So I added the cooler box.... |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
Mark please may i ask you to share pictures of the brackets for the branch deflectors as well as how they are attached (especially the lower one)
Thank you "Overlanding With Bruce" - Youtube https://www.youtube.com/@OverlandingwithBruce 11MY Defender 130 23MY Defender 110 D300 HSE X-Dynamic https://www.youtube.com/channel/UCzrHKcjA-LJ470_H4QwPgVA |
17th Feb 2022 9:28am |
01coccobet Member Since: 17 Jan 2010 Location: cervia Posts: 14 |
Your Def looks very nice! two gust is mei che one
26th Feb 2022 10:58am |
jrjones4 Member Since: 04 Jan 2023 Location: North Carolina Posts: 1 |
I ordered the cooler box and I’m going to add as well to my 2023 130. Is the wiring already there by chance to power it? If not, what’s the best way to tap the USB power? I see the cooler itself has a black and red wire going into a gray adapter. Any help appreciated.
7th Jan 2023 1:46pm |
Mark1107 Member Since: 19 Oct 2020 Location: Los Angeles Posts: 74 |
The usb plugs are the same amperage as the cooler box. The cooler box has 2 wires and the usb plugs have two wires. I just tested them on a multimeter (I cannot explain how to use a multimeter go to google to YouTube to learn that!) and stripped the wires. My back up center console had the correct plug. I cut and married it to one of the usb plugs. The cooler box just drops in. I don’t have anymore pictures sorry. 2022 Defender Trek Competition 110 collectors edition!
2020 Defender 110 P400 Full Explorer Pack 7 Seater HSE Fuji White(sold) 2020 SVO Range Rover L405 Full Size Spectral Blue Chromaflair 2014 Range Rover L405 Autobiography Full Size Aintree Green 2014 Dodge Viper GTS Stryker Green |
7th Jan 2023 5:00pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 172 |
very nice Mark, congratulations!!!!
7th Jan 2023 5:15pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 |
Nice job. This is also on my list.
I noticed your brush wire coming out of the bonnet / hood. Do you have any pictures of the bracket attachment? |
7th Jan 2023 6:37pm |
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 |
Does the cooler box have a drain hose? (I ask as it looks like an actual AC unit)
12th Aug 2023 10:44pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 |
Good work.
That's a great looking Defender you have there. |
13th Aug 2023 12:13pm |
