![]() | Home > Puma (Tdci) > Air conditioning - bi-zone ?? |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 828 ![]() ![]() ![]() |
Check the valve that is under the bonnet that the hot water goes into. Mine does not close fully and hence leaks warm/hot air into the cabin, if I push it fully closed the aircon works nicely. Think there are threads about putting springs on this valve to make it shut better. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2135 ![]() ![]() |
This is the link. https://www.defender2.net/forum/topic78660.html?highlight=valve |
Magoyo Member Since: 04 Feb 2022 Location: Buenos Aires Posts: 47 ![]() ![]() ![]() |
Thanks Race.it, I had assumed the same thing and therefore I touched the valve ducts by hand but apparently there were no leaks, but I am going to try to force the closure since perhaps the hot water leak is minimal but enough to affect the cooling. Thank you and very nice your truck by the way! |
Excelents ideas Ianh ยก i will try that and then comment how it goes |
