![]() | Home > Puma (Tdci) > Window defogger connection |
TriniDaddy Member Since: 23 Nov 2020 Location: 10.57422, -61.28906 Posts: 35 ![]() ![]() |
Hey guys. Got tint put in and the guy popped off the connectors to these it seems. In the manual there’s two connectors coming from the wire though.
Where do I get what’s missing? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 110 SW 2.4 IZUMI BLUE |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
I would ask the installer to finish the job by reinstalling the connections, normally you simply trim around these connectors not pull them off…. Doh! Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6658 ![]() ![]() ![]() |
The film fitter has ripped all 3 tabs off the glass
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
I believe one of the connections is for the 3rd brake light.
I would rip the fitter circular muscle. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
It’s correct that there are two tabs one side and one on the other (manual diagram is wrong). On the two tab side the smaller tab with clear cover goes nearest the rubber seal.
