Home > Maintenance & Modifications > Alarm activating when cranking from cold |
It's usually a sign of a low battery as the BBUS sees it as the battery being disconnected as if the vehicle is being stolen.
Mixing batteries on a split charge system isn't a problem - I've had that sort of setup for about three years without issue - but the specifics of your system could be. That would depend on how your system is wired and designed to operate. Alternatively, it could just be a duff main battery. As a first stab at it, try disconnecting your split charge system and just run with the main battery to see if the fault persists. If it does, it's more than likely the battery itself or some sort of parasitic drain (alarm, tracker, etc.). If not, then your split charge arrangement needs looking at further. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
27th Jan 2022 2:54pm |
yodaegghoover Member Since: 27 Jan 2022 Location: Somerst Posts: 4 |
Brilliant, I appreciate your help. cheers
27th Jan 2022 3:30pm |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
Last September my 2014 2.2 started doing the same thing the alarm would squeek during the ignition process, I used a CTEK MXS10 to charge it and recondition to keep it alive, then in the first cold snap and snow in January.... It died (obviously at the worst time )
Had Tayna Batteries deliver me a new one - VARTA 019 AGM (OEM is a Varta Flooded battery) No problems since While the setup is only a single battery, my inital thoughts are that the main starting battery does not have enough cranking power, this is made worse by the cold weather, since this causes the chemical reaction in the battery to slow down, this results in a drop in the cranking ampage (the volage drops due to the high amp draw during the starting) Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
27th Jan 2022 3:39pm |
Thank you Land Rover Anorak and Zee. Will get myself a new battery and go from there.
27th Jan 2022 4:49pm |
