![]() | Home > Technical > A LR Newbie with some Puma Questions |
The clutch is a known issue and you ought to be be pleasantly surprised once it's been replaced. Driveline clunks are common and there are plenty of threads on here covering the usual culprits [plus the clutch too but in the meantime check that the propshaft bolts are tight. A slower gearchange technique helps too. Steve.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4742 ![]() ![]() |
Clutch probably needs replacing. The rattle is no doubt caused by the springs. This gets worse so get it changed by the dealer under warranty.
Check underneath for any loose bolts in the couplings or if their is too much slack in the propshafts. People have said here that putting in stronger/heavy duty items in the drivetrain puts stress on other components not designed to take it. No doubt lots more info to follow. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Steve.N Member Since: 17 Sep 2011 Location: Co-Meath Posts: 4 ![]() ![]() ![]() |
Thanks for the replies.
Checked underneath yesterday when I dodged the showers - could see nothing loose. How long does it take for the clutch to give up the ghost? 10s of miles or 100s of miles? |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Hello Steve, i too came from a hiace van to a landrover - its like stepping back in time - but, you will get used to it and learn to drive your defender differently to how you drive a modern vehicle
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
