Home > Puma (Tdci) > Engine sound 2008 Puma |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 511 |
Evening all, came back from a trip out and halfway home heard this lovely sound, any ideas? No warning light, oils fine, water fine, cannot see any leaks or fractured pipes etc.
Regards Paul https://www.defender2.net/gallery/albums/u...18FC4E.MOV Cogito ergo sum |
19th Jan 2022 10:26pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
Check the injectors are tight, and not leaking.
19th Jan 2022 10:33pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2301 |
Does sound injector related.
Remove the black plastic injector cover (2 bolts at the front) You will see four injectors (blue below) held in place by two clamps (green below), each one clamping a pair of injectors. Give each injector and clamp a wiggle to check the clamps are tight and adequately retaining the injectors > 110 XS Double Cab |
20th Jan 2022 4:36pm |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 163 |
This is much like the sound that mine made when the retaining bolt shown in Hank's picture failed on the school run. The sound was caused by a tiny amount of movement of the high pressure pipe/injector. I made a bid for the dealership 6 miles away and got halfway there before the pair of injectors came completely adrift and we coasted gently to an unpowered stop.
My daughter remembers it as the day when the Landy made even more embarrassing noises than usual outside the school gate. |
20th Jan 2022 6:07pm |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 75 |
you can see injector 3 bouncing in your vid. easy enough fix with a new set of copper washers and stretch bolts. you might as well change all washers while you're there.
21st Jan 2022 11:22am |
Only get the audio when I download it > 110 XS Double Cab
21st Jan 2022 11:43am |
Thanks for all the replies everyone, took the cover off today and injectors 3/4 were bouncing around like billyho, I’m taking it in on Monday for a diagnostic check and will mention it then, appreciate all the replies, thanks once again.
Regards Paul Cogito ergo sum |
21st Jan 2022 2:09pm |
Did you tighten down the bolt? I wouldn't drive it as is > 110 XS Double Cab
21st Jan 2022 2:39pm |
as hanks says. driving it with them loose will not do the head any good.
Just give the clamp a nip up (not too much. think the spec is only 7Nm and 180degrees) |
21st Jan 2022 2:42pm |
Even if you just “nip” them up before driving. I wouldn’t recommend driving it with them loose.
21st Jan 2022 2:50pm |
Okay guys, cheers for the info Cogito ergo sum
21st Jan 2022 6:04pm |
Just a quick update, couldn’t tighten them up as away from home and no tools, drove it very slowly to the garage, it was the injectors, tightened up, full diagnostic, running sweet, thanks again for all the help, much appreciated Cogito ergo sum
26th Jan 2022 12:25pm |
Glad it was a nice simple job.
26th Jan 2022 12:49pm |
