Home > Maintenance & Modifications > Defender DCPU 2nd Row Seats
Dry Bones
United Kingdom 2004 Defender 110 Td5 XS DCPU Bonatti Grey
Hi,
New to the forum so thanks for accepting me.
The 2nd row seats in my double cab are awful (TD5 bench) and family hate being in back for any period. Apart from the expensive Puma option has anyone else fitted anything that still gives legroom and semi comfort in theirs?
Thanks in advance folks.
Post #939301 24th Jan 2022 10:19pm
The second row in a Puma DCPU is actually not that much better, due to the angle of the backrest having to be more upright than in USW or SW models, coupled with a chronic lack of legroom.
Post #939307 24th Jan 2022 10:44pm
Dry Bones
Thanks for the reply.
Thats exactly what the missus as been saying, lack of leg room and just rubbish seating.
Dont think can do much with the legroom issue, but thought if could find something to put in there that made it a little more comfy may help.
Saw online a couple of folks put range rover sport seats in, but not sure if that makes leg room worse.
Post #939309 24th Jan 2022 10:47pm
Grenadier
On going balance between comfort/leg room/journey time.
Puma seats, as Blackwolf mentions, are just as upright (they’re thicker and taller than the bench), but more comfortable on the bum in terms of squishiness. But they’re also longer so if any in your family are above 5’ 8” they’ll struggle. Especially if you have upgraded your front seats to buckets (as I have - Recaros) which bulge more at the back than standard Puma seats and have a hard casing.
Then there’s front driver and/or passenger height. I’m lucky in that my wife and I are lower to the ground, so we have the seats a little bit further forward than a taller driver/passenger. So our passengers in the rear have a little more leg room.
Also, Puma head rests actually drop down the front of the seat when lowered. This pushes the head/neck forward. Many (shorter) passengers complained, so I take mine out when we have visitors (no daily users as no kids).
There are spacers you can buy which lift the front bracket of the Puma seat up and away from the seat box below, thereby allowing a gentle tilt back. But you’re back in the realms of ‘leg room’. So fine as an option for shorter passengers or for taller passengers on short drives with front seats pulled forward if possible.
My plan is to do a combination of things. I’m planning to eventually have a four seat Recaro set up, but heavily adapted. I’ll put the riser on the front to lift the seat base. I’ll cut the front edge of the recaro seat base and take it back by an inch or so (it is quite long and protrudes beyond the sides) and then fold the leather back in. And I’ll cut the rear casing out at a height below the lower edge of the rear sliding window so that it can push back to the back of the cabin without being stopped by the bulge in the casing. As you can’t see from behind, it doesn’t matter that the internals of the seat are exposed. I’ll then lock the seat in place at the optimum lean (Recaros already allow you to sit deeper than Puma seats) and hopefully offer max comfort. Thumbs Up Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #939362 25th Jan 2022 10:21am
There are upsides to the Puma second row, however. For example after a very short time the kids won't want to come with you when you go out in your DC Defender, and you won't get loads of mates wanting a lift to the pub with you! Very Happy
Post #939367 25th Jan 2022 10:44am
