Home > Maintenance & Modifications > Door hinge replacment bolt pattern |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3382 |
I believe that the early vehicles had UNFs and were all Phillips (they are probably pozi).
When there was the change to metric, they were the star (torx). If you have a combination, probably a previous owner replaced some screws, not others. So ensure you have the correct captive plates that fit on the bulkhead, either UNF or metric depending on the screws you have (most likely your new kit is metric). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
25th Jan 2022 7:30am |
GRU54 Member Since: 03 Oct 2021 Location: Nashville Posts: 26 |
Yes I did get metric bolt Torx pattern to use. Most all of my old bolts were corroded. Thanks.
This was not the easiest thing Ive ever done. |
26th Jan 2022 11:46pm |
