![]() | Home > Tdi > Oil in pipe? |
JLRyall Member Since: 24 Jan 2022 Location: Hampshire Posts: 7 ![]() ![]() ![]() |
![]() Click image to enlarge Is there meant to be oil in these pipes around the turbo? |
donmacn Member Since: 06 Nov 2017 Location: Nth Scotland Posts: 1852 ![]() ![]() |
Don’t know about “meant to” but it’s not uncommon.
If you follow the pipework you’ll see that on the inside of the bend in the big pipe in your photo, there’s a small pipe coming in from the rocker cover oil cyclone. This is how any crankcase pressure is fed back to the air inlet side - along with a healthy dose of oil as the cyclone may not be working as well as it should if at all. They are cheap to replace with OEM, or more spendy to replace with something bling. A more complicated ‘fix’ would be a ‘catch can’ - you can search on here for an explanation to that. Probably thousands of Tdis running around with oil in that pipe and as long as it’s not truly excessive it wouldn’t really matter. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
8619simon Member Since: 04 Nov 2016 Location: North Wales Posts: 254 ![]() ![]() ![]() |
Ha beat me to it ![]() |
