Home > Maintenance & Modifications > Fuel Gauge
Andy247
United Kingdom 2001 Defender 90 2.5 TD HT Masai Red
Fuel Gauge
Hi All
I am looking for a bit of help with the fuel gauge , I was driving today with a good quarter tank and only going local. After about 5 mins the fuel gauge started to drop steadily with the light coming on and then hitting empty. Got out and checked for a leak but nothing so continued with the journey with no other issues.
Got back home and turned the engine off - back on but the gauge stays on the empty and does not move.
Any pointers would be appreciated.
year 2000 W plate 90
Thanks
Andy
Post #939120 24th Jan 2022 1:28am
Davy
Ireland
I had this problem. Turned out a wire on the float in the diesel pump had broke. Pump out cleaned up and blue wire connected,,bingo.
Post #939773 27th Jan 2022 8:01pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Interesting actually. My 110 is a 300tdi but with a later td5 type plastic tank and RoW fuel level sender and pick-up fitted.
Wired it in to my 300tdi loom and gauges and all worked spot on for over a year until it suddenly jammed on hard full. This lasted about 6 months until it equally as suddenly started to work again?
I did poke around all the connectors and gauges etc but couldn't find a fault, although the gauge would work properly when the correct wire was shorted to earth..... Never did find out why.
Post #939797 27th Jan 2022 11:26pm
donmacn
Why ‘RoW’ level sender? I ask because I have the same sort of set up - a 300Tdi, but a later plastic tank.
I went with the Td5 gauge to try and pair the gauge and sender better, but I think there must be something else in the Td5 wiring to damp oscillations. The gauge works, and reads more or less Ok, but the needle swings about as the level in the tank changes (up/down hill, round corners etc).
I have asked about this before, but I think the answer was something to do with measuring resistance (complicated - for me!).
Would a RoW sender do the same thing? Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #940004 29th Jan 2022 9:31am
Martin
Site Admin
The Td5 speedo damps the fuel gauge signal and drives the Td5 gauge.
All Defender senders before the 2.2 Puma are the same electrical spec and are all therefore compatible with any pre 2.2 gauge/cluster.
So a pre-Td5 gauge can be used with any pre 2.2 sender.
The plastic tank “99MY ROW” 300 Tdi sender unit was used on the 2.4 Puma.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #940005 29th Jan 2022 9:46am
donmacn
Thanks Martin,
I think you replied to my last post on this as well. Electrics isn’t my strong suit.
If I understand what you’ve said, then by going back to a 300Tdi era gauge I’d get a better match between gauge and sender?
I don’t have the Td5 speedo or cluster installed to damp the signal. Donald
in the past..
Post #940008 29th Jan 2022 10:22am
Martin
Site Admin
If you don’t fit the Td5 speedo you can’t really use the Td5 fuel gauge. Use a pre-Td5 gauge which is internally damped.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #940009 29th Jan 2022 10:23am
donmacn
Excellent - thanks again. Donald
in the past..
Post #940010 29th Jan 2022 10:24am
I Like Old Skool
I might be wrong but doesn't a td5 tank sender include an in tank lifter pump? The RoW sender is without the pump as that is on the engine.
Post #940042 29th Jan 2022 4:32pm
