![]() | Home > Tdi > Oil Leak from where?? Defender 90 Tdi300 (1994) |
Cubflyer Member Since: 25 Sep 2021 Location: Suffolk Posts: 278 ![]() ![]() ![]() |
Hi folk
I was out and about for a couple of hours this morning, came home, parked up then about an hour later went to the Defender and noticed a small pool of oil on the floor ... Got underneath and took these shots. Number 3 was where I wiped off some oil: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Can anyone tell me the proper oil pipe titles/purpose and can anyone share there experiencies please. MTIA John 2010 Defender 90 300Tdi CW (White/1994) 2021 Defender 90 300Tdi SW (Blue/1994) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5865 ![]() ![]() |
I think that is your power steering pump, and it’s pipes. Is the fluid dark red?
Hi Andy ... I'm pretty sure it was black like dirty engine oil the the pool on the floor was definetly black. 2010 Defender 90 300Tdi CW (White/1994)
Morning Mick - Thanks for your comments, going to get underneath again today and do it bit more cleaning then run it to pin the leak down. Maybe it is not the steering hose area as first thought
![]() As I replied to Andy above, not red fluid but black: Watch this space ![]() 2021 Defender 90 300Tdi SW (Blue/1994) |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
It may be worth trying to clean inside the drain hole too. A rolled up cloth with some brake cleaner on to remove as much oil as you can, then something clean at the end to check how clean it is.
Watching with interest as I have a leak/leaks that I need to identify them. I think one of my is the rear crank - joy! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3533 ![]() ![]() ![]() |
I find it baffling that you have oil on the steering drag link. That is quite forward (somewhere under the front cross member, just behind the bumper). So could there be a tiny leak in the intercooler... but really guessing. How if the front cross member, is it dry? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
My Defender came back from a Cam belt change today and the oil leak fixed too. A seal has been replaced which led to the oil leak dripping out of the timing belt breather hole ...
Another fault fixed ![]() Thanks for all your inputs ![]() 2021 Defender 90 300Tdi SW (Blue/1994) |
