![]() | Home > Td5 > Cant Fill up |
That is very odd. Grab a torch and have a look down the filler nozzle. I wonder if someone is playing a practical joke on you and has stuffed a rag or something down the filler pipe. I hope not, but stranger things have happened.
1. check top pipe is not blocked or collapsed or kinked as this fuel tank fill vent
![]() Click image to enlarge also with age these pipes will crack and can brake easy 2. Look under passenger side rear wheel arch for fuel tank vent and make shore it not blocked with mud this is tank vent with filler cap on ![]() |
DaveC123 Member Since: 21 Jan 2022 Location: Warwickshire Posts: 2 ![]() ![]() ![]() |
Thanks for getting back to me so quick
I will have a good look at the breather pipe at the weekend Dave C |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
1996 possibly have the fuel tank under the driver seat, but should be same design as above, large flexible pipe for fill-up and a smaller one as breather.
Some (ex military?) had a filler extension with a mesh... never seen one in person though. Perhaps mesh is blocked. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
