Door wiring rubber gaiter | |
Does anyone have any info on the best access points for this into the bulkhead to the engine bay and info on where this area behind there can be accessed from.
I want to run a small amount of wiring from the interior into the door, I’m thinking that this is not possible and will need to go out though the bulkhead grommet behind the dash bin I left area across the top of the rear of the engine bay bulkhead and down to go back in though each side of the wing somewhere.
No doubt if I know what a Puma is there will be a lot of annoyance and difficulty with the job and will take five times longer than what it usually should.
The cable is 10mm max OD, but if pushed I could bring that down to about 6mm if I had to as I know the door gaiter rubbers are not over large on the internal dia.
The main part I’m interested in is the access points with the door rubber gaiters to bulkhead and out.
Info appreciated, I have had a look but not investigated a great deal yet. No Guts, No Glory.
18th Jan 2022 3:22pm |
