![]() | Home > Faults & Fixes (L663) > Creaking/Cracking sound from Rear Door |
dizeeduckie Member Since: 10 Sep 2021 Location: London Posts: 62 ![]() ![]() |
I think you might find it's the rubber trim at the top of the door?
I have it on all my doors but haven't found a solution. |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 192 ![]() ![]() |
Did you manage to get this diagnosed and repaired? Mine's doing the same now and I'm booked in at the dealers next week... Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
Same happens to mine, every few months i take it to the dealers to get them to
lubricate the door rubbers. Some people are swearing by Gummi Plfege as a solution, you can apply it as soon as the creaks return.. not tried it myself though yet ![]() MY20 110 P400 SE Defender MY10 3.0 RR Sport |
vlad Member Since: 11 Oct 2020 Location: RO Posts: 67 ![]() ![]() |
Every few weeks I have to grease the rubber seals on all the doors and the sunroof.
The LR service uses this exact grease, so I use the same one: https://products.liqui-moly.com/silicone-g...ent-2.html MY2021 Defender 90 P400 SE |
66north Member Since: 08 Oct 2010 Location: The North Posts: 104 ![]() ![]() |
The sound suddenly disappeared so whether I cured it with the lube eventually doing its thing or it simply cured itself I don't know.
Took the car to the dealers yesterday. They adjusted the doors and lubed the door seals which has (for the moment at least) solved the issue. Current: MY22 P400e SE
