Home > Td5 > Seatboxes and door cards |
Hello. I have a 2003 Defender and the door cards sit snuggly against the seat box matting.
13th Jan 2022 7:19pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17559 |
I imagine that it is the same as the TDCi, and on mine the carpet has polished the door card, there is so little room.
13th Jan 2022 7:32pm |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 635 |
Often the door cards have depressions from contact with the seatbox. They also used to contact the dashboard fascia of the Td5, so the dash was factory fitted with adhesive velcro strips to stop the creaking.
13th Jan 2022 8:28pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3471 |
Check that you have even gaps (or lack of) driver and passenger side. I know the bolts that bolt the seat box to the tub are M6, but the holes may be a bit larger to accommodate the higher tolerances of the Defender. The seat box bolt holes to sills (3x per side) and to the 2 brackets on the chassis (1x per side), aft of floorboards, are quite generous in size. Perhaps the seat box is slightly shifted to one side. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 956 |
Nope! Tight but not touching and yes I have power windows and door locks.
Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
13th Jan 2022 9:37pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 |
Thanks for all the replies everyone, I'll look at the seat box positioning at the weekend.
13th Jan 2022 10:26pm |
