![]() | Home > Td5 > Bonnet hinge bushes |
The thin side goes next to the bulkhead and when the bonnet is closed rotates towards the engine.
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Ive just noticed you have a rubber seal across the bonnet/bulkhead .Is that standard for older defenders as my puma doesn't have one? ......... bloody good idea as mine gets full of sh*t!and its a rust trap! Anybody done this on their pumas?.Or alternatively is it standard and LR just forgot to put it on mine?
Do a search on eBay for Saab 900 bonnet seal. I took it off an old 900 and it fits perfectly, stops rattle, and reduces noise and it keeps
![]() ![]() ![]() https://www.ebay.ca/sch/i.html?_from=R40&a...p;_sacat=0 ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Thanks thats a great idea!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3029 ![]() ![]() |
Second recommendation for a bonnet/bulkhead seal here, l used self adhesive D-seal and it made a noticeable reduction to noise levels particularly when the vent flaps are open.
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5264 ![]() ![]() |
i wonder if this seal mod may help stop water from entering the engine bay and into the cabin floor pan Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
Procta, it does keep a lot of
![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2163 ![]() ![]() ![]() |
Another
![]() I added a double length to each side of the bonnet. ![]() Click image to enlarge ![]() Click image to enlarge I also had a ‘factory fitted’ seal on the bonnet against the bulkhead. ![]() Click image to enlarge Not sure it does very much, and doesn’t look as effective as the Saab 900 version, but I added a D seal to that also. ![]() Click image to enlarge Does it make any difference? Well as Defender owners we can probably all be prone to a little of the Placebo Effect. I think it’s quieter… |
It is defo quieter. I measured db before and after and it was 4db drop. You really notice it when you open the vents. No diesel clatter.
![]() Yes the noise when the vents are open is definitely quieter. Looks neater too. Can now hear the wife clearly… |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3531 ![]() ![]() ![]() |
Was getting interested, but changed my mind ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
