![]() | Home > Puma (Tdci) > Fan / Clutch Part Number Question |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3528 ![]() ![]() ![]() |
Check out this post.. I think you are not alone.
https://www.defender2.net/forum/topic71379...emperature 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
MGRGPGBG Member Since: 19 Dec 2017 Location: New York Posts: 67 ![]() ![]() ![]() |
Thank you
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2322 ![]() ![]() ![]() |
I see that you are now sorted, however you should find the VIN number on a plate in the bottom corner of the windscreen, as well as stamped into the chassis leg. > 110 XS Double Cab
Hank - This engine came out of another truck. I do not have a VIN from it as I bought it as a stand alone engine/tansmission that I put into my 1995 chassis and body.
Thank you for this link. From this I was able to see / test that the fan clutch is not engaging at startup and cold start. Embarrassed to also say that I did not see the part number molded into the fan blade when I was looking at this in the dark the other night. Today as it is warmer I pulled the shroud and see the part number on there now. So seems that all is working mechanically and that possibly the cause is that I have over sized Allisport aluminum radiator and intercooler. Thanks again! |
