Home > Maintenance & Modifications > Building a Jaguar V8 powered 90
Page 2 of 3 <123>
L110CDL
Great thread but i have finished my pop corn already Rolling Eyes
Looking forward to the next update Very Happy Clayton.
Keeper.
Post #937422 12th Jan 2022 10:10pm
Caterham
is this the v8 they put in the v8 works?
if so I've been informed by someone in the know that getting it to work correctly will be nigh on impossible?
Post #937860 15th Jan 2022 6:26pm
It has been done.
Post #937867 15th Jan 2022 7:17pm
kenzle8a
It can't be any harder than fitting an LS can it? LOF did one (Edit they did a ford Coyote), I'm right in thinking a lot of the mounts / parts came from blackbird industries for the works one.
Since the 4.2 is the same ish engine and uses the same autobox as the M57's I don't see it being too much of an issue.
Post #937882 15th Jan 2022 8:45pm
takoon
Norway
I’ll guess it is the 4,2 you are installing as it has a dipstick ( the 5,0 lack this)Will it be the supercharged or the NA? Would like to do the same conv. on my 90`. Good luck Thumbs Up -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio
Post #938615 21st Jan 2022 7:38am
Caterham
knowing someone at jlr they implied that doing what jlr had to do for the anniversary edition was not possible / viable for a 3rd party to do? I think this has more to do with the electrickery more than the mechanics.
hence why the coyote is a favourable alternative.
Post #938723 21st Jan 2022 7:17pm
kenzle8a
Tbh if you can stuff a twin turbo x5 engine in a Defender I would think that the jag one can be used to with some poking about
Post #938749 21st Jan 2022 10:15pm
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
How is this build going?
Be interesting to see if you've gotten any further.
If you're stuck on the hurdle of which box to use there is a manual box that will fit the AJ-V8, its used in the s-type Jags. S6-53. I believe there to be an adaptor to the LT230 already for that Gearbox although, designed for the AWD version that came from manual Disco 3/4s. Just a thought.
as well as Gear selector adaptors too. 4.0 V8 Defender 90
My Instagram
Post #998856 6th Jul 2023 11:38am
Chicken Drumstick
Sorry, but that is utter BS. Engines aren't magical boxes running on pixie dust. All you need to be able to do is control the air/fuel/spark. Not saying it will be easy, but the Jag V8 doesn't do anything fundamentally different to any other engine. So there is no logical or rational reason why it can't be made to run.
Post #998874 6th Jul 2023 12:58pm
Chicken Drumstick
Re: Building a Jaguar V8 powered 90
Jim G wrote:
So , its been a very long project !! I bought a 90 in 2017 to put a Jag V8 in . However it was a total rot box , with 9 months MOT !!!!
So before I could start, it took a year to sort the rust etc and get the chassis and bulkhead galvanised painted and ready to be rebuilt .
I have been looking at fitting the Jaguar V8 ... a much much much more difficult project than I first thought. However I now have the engine in the chassis, and a MANUAL drivetrain sorted ( I now understand why JLR.... very sensibly... have never produced any vehicle with this engine and a manual gearbox) .
I was not happy with the way that JLR had fitted the V8 to their Defenders as it is in on an angle, very far forward and quite high in the chassis. I have engineered mine to be approximately 100mm lower and 150mm further back , level as in the JAG, and with a 6 speed manual gearbox ( that will take the power) ...I think it needs to be as far back as possible to help with weight distribution on such a powerfull ( short wheelbase) vehicle... did I mention that this has been a VERY difficult project !! My original plan was to 'just fit the engine' them sort the more difficult problem of the ECU
Any updates on this?
For reference, Jaguar did build a manual, but only in the form of the XK180 concept car. However I believe there is a firm that has done manual conversion in something like an Elise platform running the Jag V8 engine.
And of course JE Engineering offer the Jag V8 engine in a 90 over a decade ago with a manual box.
e.g. something like this:
https://moto-drome.com/about-motodrome/cur...ged-99995/
The ZF-6 speed as used in the Disco 3 or various BMW products should mate directly to the engine without an adapter. But you need to solve the flywheel. JE wouldn't tell me what they used, but did say it would need "fabbing".
There are conversion kits to mate the ZF-6 speed to the LT230.
So it should then just be a matter of getting the engine running.
Here is a Jag powered trials vehicle. Not sure if it is a 4.4 or 4.2, but it is running the ZF 6-speed manual and RRC style Borg Warner chain driven transfer box.
Post #998882 6th Jul 2023 1:16pm
LJMARSDEN
I find it odd the fact that these 4.2s are not more mainstream. I don't know much about their reliability but the units are everywhere and not that expensive. the biggest problem is simply management. however, I would have thought that with enough interest a plug & play solution would've been developed.
Would love to have had one of these instead of a 1UZFE simply for the added 100bhp and the bragging rights a supercharger gives Rolling with laughter 4.0 V8 Defender 90
My Instagram
Post #998887 6th Jul 2023 1:26pm
Chicken Drumstick
I agree. I'm amazed nobody has developed a simple plug & play ECU solution. The Jag engine is the ideal conversion engine IMO.
Rover V8's are getting harder to find and as nice as they are, they are 150-250hp engines unless you spend BIG money on them.
The AJV8 can be had for as low as £300 from a breakers and comes in a variety of displacements and outputs.
Any other transplant engine is far less viable in the UK. I love the LS engines (have one in my Camaro). But in the UK you just don't find them in breakers yards. Nor is the Chrysler Hemi or Ford mod motor (aka Coyote). And nothing BMW or Merc is really all that suitable or desirable.
Plus using the AJV8 keeps it 'in-house' if you know what I mean.
I've contacted a number of places over the years. But oddly there seems to be no appetite. Not sure why... maybe they are only interested in wanting to flog LS conversion for £80-150k, despite only costing about £10-12k to build.
Post #998908 6th Jul 2023 3:38pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Modern ECU do more than just control the spark and fuel. That's what makes them tricky to swap over as part of an engine swap. However, there are numerous stand alone ECUs from various manufactures available. I've used Motec in the past. Getting the ECU connected up is easy, the tricky part is developing the map. This takes many hours on a rolling road which soon gets expensive.
If I had the time and the money, I'd like to try the JLR 4.4 diesel V8 in a Defender.
Post #998922 6th Jul 2023 4:15pm
Chicken Drumstick
TDV8 is another story.
But on the ECU side. It depends, if you are transplanting a modern electronic controlled transmission too, then maybe yes. Otherwise in theory all you need to do is bypass any sort of immobiliser type thing and BECM controls and just stick with the engine. As you aren't wanting to control things like EAS, emissions stuff or anything else from the source vehicle. You just need to pair it down.
As above, I posted a video of an 80" CCV motor running the Jag V8. So it clearly is 100% possible with the right knowhow.
I can't see that making the Jag engine run in another vehicle should be any more challenging than getting any other modern engine to run in another vehicle. And engine swaps are hugely popular and common in the motoring world.
Post #998924 6th Jul 2023 4:26pm
JOW240725
IIRC Bowler fit the Jag V8 into the Bulldog and Wildcats etc, so is certainly possible. I know they're part of JLR now but surprised they don't offer a solution. James
Instagram @suffolk_rovers
Post #998974 6th Jul 2023 10:14pm
Page 2 of 3 <123>
