Home > In Car Electronics > Wire to extend switches
pilsburypie
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Next week going to do my double din conversion. Got the double din dash from mud stuff which comes with comprehensive instructions. Mentions extending the switch wiring for the auxiliary panel install.
Can someone point me to the appropriate wire I need to buy? Not taken anything out yet so have no idea!
Post #936764 7th Jan 2022 10:40pm
I think there is pre made looms you can buy that have appropriate wires and plug / sockets already fitted.
I’m not sure who though, but I’m sure there is such availability. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #936765 7th Jan 2022 10:53pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
The forum shop sells them, switch extenders Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #936768 7th Jan 2022 11:44pm
Race.it
Looks like forum shop for cables etc is offline at present due to the semiconductor issue around the world
But you have them here also https://www.mudstuff.co.uk/products/defend...ions-loom, also on the bay of evil you can get the blank connectors etc if you wanted to make up your own Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #936769 7th Jan 2022 11:50pm
pilsburypie
Thanks for the info, but I was rather thinking of just purchasing a load of correct gauge wire (which is?), cutting the original wiring in the middle and soldering an appropriate length of wire in. Sure this is a faff, but with the nice and easy mud stuff plug and play extensions being £36 a pop, that’s £180….
Post #936822 8th Jan 2022 1:05pm
Does anyone know of a source of the male connectors used on those extension harnesses? The bit that the original connector plugs into instead of the switch.
I'd be grateful for a link or similar.
Many thanks.
Post #936827 8th Jan 2022 1:21pm
Race.it
Blackwolf no idea prob some place in the Far East.
Pilsbury pie you may not need to extend them all, I actually needed zero after buying one, as I could put the switches in other locations Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #936829 8th Jan 2022 1:35pm
dorsetsmith
Pic will help
Post #936832 8th Jan 2022 1:46pm
Niels906
Netherlands
Pics of wires
Hey everyone,
I'm about to order the double din unit from defender upgrades.co.uk. Any one have any pictures as to the wire situation? Would be nice to know what I'm about to get myself into Wink
Thanks,
Niels
Post #938673 21st Jan 2022 1:36pm
Race.it
I fitted mine without any need for extensions, just moved switches to locations they would reach. Searching for my first Defender...and started just as Covid hit, so talk about timing.
Post #938680 21st Jan 2022 1:50pm
I would ask PaulMC on here regards connectors, along with Martin they are both very knowledgable about them..
Some of the connectors are unique and are quite difficult to identify.
PaulMC has kindly helped me many times for connectors and wiring items. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #938692 21st Jan 2022 2:19pm
Martin
Site Admin
5 pin extension
I developed the 5 pin socket for this as there's no available matching connector for the plugs.
Hazard extension
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #938706 21st Jan 2022 4:17pm
ant.
Ate the switch extenders still available?
I need two 5 way and the hazard one
Post #974179 10th Dec 2022 5:31pm
Martin
Site Admin
I've got another batch of the 5 pin sockets due any day.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #974180 10th Dec 2022 5:32pm
ant.
Thanks Martin...will they be in the shop?
I need them for heated screens, front and rear.
Presume all the same?
No hazard switch ones?
Dont mind extending one switch though...
Post #974182 10th Dec 2022 5:46pm
