Home > Puma (Tdci) > Best Place to Buy a new Wiring Harness Loom
Doodlefish
I am looking for the best place to buy a new wiring harness loom for 2.2tdci (2013). It should be the wiring kit with MAF connector etc... (not sure of the part code).
Is it different for the 2.4?
A reliable source please as I do not have much faith in ebay these days and the costs are all over the place.
Thanks.
Post #936409 5th Jan 2022 10:41am
Martin
Site Admin
I think I've still got one in stock:
Made with OEM connectors.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #936414 5th Jan 2022 11:26am
Doodlefish
Thanks Martin
I need the entire loom including the MAF connector. Not just the MAF Connector. I have 2 of those already. The one pictured is similar but they usually have 2 wires that are grey and purple.
Post #936419 5th Jan 2022 12:08pm
Martin
Site Admin
There is no LR part number for a 'part loom' like that, you'd only get a whole engine loom - unless you have it custom made (which would likely cost more than a good second hand entire loom).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #936422 5th Jan 2022 12:25pm
Doodlefish
Yep. i need the entire loom but looking for a good supplier at the right price of course.
Post #936423 5th Jan 2022 12:29pm
Assuming that you mean the full engine harness, then I am sure it is completely different between a 2.4 and a 2.2.
I am also sure it will expensive. Sad
Post #936425 5th Jan 2022 12:56pm
Doodlefish
Anyone know where I can find the wiring harness loom which includes the MAF sensor connector?
Post #936430 5th Jan 2022 1:42pm
Martin
Site Admin
All 2.2 engine harnesses will have the MAF connector - not sure why you keep mentioning it as if it wouldn't?
The LR part number is
LR058089 £430 +VAT full LR price  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #936439 5th Jan 2022 2:19pm
Doodlefish
Hi Martin. Thanks for the information.
I am not hugely knowledgeable on the electrical components of my land rover and there are a numerous wiring assemblies all over the car. I just wanted to clarify what I needed to make sure I only purchased the minimum as well as to avoid confusion...mainly by me. Thanks again.
Post #936441 5th Jan 2022 2:27pm
As Martin has said and as I intimated, the MAF sensor connector is part of the engine harness, and the engine harness is significantly different between the 2.4 and 2.2.
The engine harness includes all the wiring between the ECM and the engine and related sensors, including the charging and starting circuits, aircon, turbo actuator, and on the 2.2 no doubt the DPF and related sensors, etc. It is a substantial harness.
A Google image search of the part number Martin has provided will show you the harness, which is the minimum you would need to achieve the result you say you want.
Post #936443 5th Jan 2022 2:33pm
Martin
Site Admin
OK - I understand now Thumbs Up
The engine loom is "one piece", but changing the whole thing for damaged MAF wiring would seem overkill unless you think there is hidden damage that would cost more to find and fix than a whole loom.
LR don't do the MAF plug and wiring as a separate part (I do/did) and it's the same part as original.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #936444 5th Jan 2022 2:33pm
Doodlefish
Thanks Martin
I have changed the MAF sensor and the MAF Connector (soldered and taped to the existing wiring loom), to no avail, but I have also had a mouse in residence and its gonna be a Censored to find a nibbled wire. Hence the lookout for a new setup. Sods law says the problem isn't the wiring but am running out of things to replace. Triggers broom.
I should point out I have another topic dealing with the issues and this one was simply to source the wiring. Hence you wont necessarily know how I got to this stage.
https://www.defender2.net/forum/topic81269.html
https://www.defender2.net/forum/topic81732.html
Post #936445 5th Jan 2022 2:52pm
dorsetsmith
If haven't all cared this out unplug MAF-IAF plug and ECM plug C2518 bottom plug on the ecm and check with Multimeter pin to pin between two plugs
maf plug pin 3 12v +
----------------- 4 to ecm plug pin 15-------------- C0162-6-----C0448-6
------------------5 to ecm plug pin 25--------------C0162-1-----C0448-1
------------------2 to ecm plug pin 9 ---------------C0162-5-----C0448-5
plugs C0162 and C0448 are in between maf and ECM on the engine loom LH side of transfer box
check open cct wires and shorts between wires high Resistance between one end and other
Post #936452 5th Jan 2022 4:34pm
Doodlefish
Will try that. Thank you. I'll let you know the result.
Post #936456 5th Jan 2022 4:50pm
dorsetsmith
Exclamation
have you had the clutch changed or gears box out ? had one with the two plug down LH side transfer box not seal and and water in side
Post #936460 5th Jan 2022 5:08pm
