Home > Maintenance & Modifications > ARB compressor under Puma Driver Seat |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5731 |
I thought you would just run a single compressor to do both jobs. Possibly add a pressure vessel but that can be anywhere in the system. There is a main supply that runs from the batter across to the opposite seatbox should it be required.
2nd Jan 2022 11:01am |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2644 |
Most installations are only a single compressor , as let’s face it, you will only ever be using one at a time as their purposes are different
2nd Jan 2022 11:07am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2247 |
Along with Andy and Mark, I can't see why you need 2 compressors for your intended use. Spend your hard earned on a rear locker
2nd Jan 2022 11:28am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I used a6mm ring terminal piggy backed of main battery supply to fuses under driver’s seat 👍
2nd Jan 2022 11:40am |
Westy Member Since: 28 Sep 2017 Location: Scotland Posts: 11 |
Having had an ARB onboard locker overheat whilst airing up tyres I have since always carried the Viair compressor for tyres and use a dedicated compressor for lockers.
Thanks for replies I have been tinkering all morning and have soughted the switch illumination via cigarette socket and fixed the earth lead. Having a cuppa before soughting out the positive terminal. Rear locker is in transit so hopefully once Nigel at Xcess4x4 has worked his magic ill be soughted by end of February. |
2nd Jan 2022 12:39pm |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 399 |
I run the same compressor but have it squeezed between the seatbelt and the body, fits perfectly and is very discreet. On advice from nige at xcess 4x4 I use a separate compressor for tyres.
One thing I would say about the switches on the cubby box, when they are illuminated I found that they shone on the windscreen which was very annoying so ended up disconnecting the illumination |
2nd Jan 2022 1:16pm |
I have been thawted as I was wiring a fuse (15 amp) between battery positive and compressor and found the fuse holders I had bought months ago are for micro fuse not standard and of course I only have standard fuses in my kit!
Also the switch illumination has stopped working for some reason I can not fathom. Checked all connections and they are good, so called it a day. |
2nd Jan 2022 8:46pm |
A standard arb compressor has its own inline fuse🤔
2nd Jan 2022 10:23pm |
I was going by the wiring diagram that stated 15amp fuse. I'll look again in morning in case I missed something.
2nd Jan 2022 10:40pm |
The small ARB does not come with its own inline fuse, or at least it didn’t when I installed mine so don’t think you’ve missed anything westy
3rd Jan 2022 9:40am |
Fuse is in the loom
3rd Jan 2022 10:05am |
Fuse isn’t in the loom on the one being used here, requires a 15amp fused supply
Click image to enlarge |
3rd Jan 2022 10:09am |
Obviously the newer ones don’t have it
3rd Jan 2022 12:18pm |
Well I just received the correct size fused connections. I have installed the fused connection to the battery positive with a 15amp fuse as per diagram.
Checked all connections including earth and compressor is still not working.! Would it require the pressure switch plumbed and wired in to work or is the switch wiring shown in the top diagram of the switch connections incorrect as I think I saw a post about the wiring before? |
5th Jan 2022 4:06pm |
