![]() | Home > Puma (Tdci) > MY 2015 auto box install USA |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 512 ![]() ![]() |
What year and engine do you have? Taking the body off is total overkill and unecessary for the conversion
Bullet proof a Puma? Go LS3
I’d have thought the mt82 was more reliable than the thing it’s bolted too
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2275 ![]() ![]() |
Says 2015 and mentions a DPF, so that will be a 2015 2.2 TDCI. On point 2 . If doing the silicon hoses don’t forget the elbow one to the inlet manifold, a real awkward one to get to but one that does fail, two members had it fail this month. https://www.defender2.net/forum/topic81674.html On point 3. You will need a remap to delete the egr and DPF, worth contacting Bell auto services https://bellautoservices.co.uk/ They also have the intercooler and hoses for sale plus if you go for their remap you also get the IDtool as part of the remote map capability and it is an excellent diagnostic tool. Given there a few people in your area that know defenders I expect having the tool will prove highly beneficial. |
El Jefe! Member Since: 25 Feb 2019 Location: USA Posts: 4 ![]() ![]() ![]() |
Yup, going to contact them, looks like i can pick up everything i need from them. Looking forward to getting this done over winter.
Oldyellar Member Since: 04 Sep 2015 Location: Central Posts: 411 ![]() ![]() ![]() |
Get the dpf out, get a catch can fitted. Amd keep am eye on the injectors, if it starts slight reving up higher than you have pushed the throttle pedal it's starting to over fuel you will eventually hole a piston
100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411 ![]() ![]() ![]() |
The entire LS thing is way overrated. Ask yourself why hardly anyone put his Def on a dyno after the conversion and comes up with the real figures. Done my L98 (one of the first new crates available in the world at that time) in 2007/08 and dyno tuned it btw. m |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2664 ![]() ![]() ![]() |
silly question, is the 25 year import rule different when importing a car in from Mexico as oppose to the UK?
Cant say that i have ever thought about it before. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17728 ![]() ![]() ![]() |
Don't forget that the MT82 has a poor reputation in the 'States where it is usually found in its Chinese form in the Mustang. There will be a tendency to tar the better Defender box with the same brush. |
yes, its the same 25 year rule, but its really not here, its here, but its not here ![]() |
I think once the swap is done and the tuning is complete, it should perform just fine, gas is $5 a gallon now, i don't need or want a V8, if i want to go fast, I can drive something else |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
As I understand it the problem with the MT82 is not the place of manufacture but a design fault by Ford Getrag. It can’t handle fast gear changes at higher revs. You probably won’t notice it when pootling around in a Defender or Transit but it was a real problem for the Mustang. Blackwolf will know it’s technical deficiencies better than me but those with a Puma try a quick standing start and more often than not it will mess up changing into 3rd gear. An uprated clutch helps a bit but it still a POS by modern standards. I also read the MT82 is only designed to take a maximum of 370nm which is may account for so many Mustang failures in the US. Ford’s budget parts-bin design attempt at the Defender was a complete disaster. Ditching the (excellent for the time) TD5 for a Transit engine that frequently blows up and can’t be reliably tuned more than 200bhp plus rubbish gearbox, not to mention that poxy output shaft. IMO the Td5 was a much better truck with the exception of the dashboard design. WARNING. This post may contain sarcasm. |
