![]() | Home > General & Technical (L663) > Land Rover Roof Box |
Ritson Member Since: 11 Apr 2021 Location: France Posts: 189 ![]() ![]() |
Has anybody purchased the Land Rover Roof Box specific to the Defender? If so what are your thoughts about it? I'm thinking of buying one, as they seem to be only marginally more expensive than other manufacturers (such as Thule) but would, I assume, be easier to fit / remove as is custom made for the Defende.r Current: MY22 P400e SE
Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1766 ![]() ![]() |
I would think the genuine box is Thule bearing in mind they manufacture the genuine rack.
Thanks for the advice
I'll look into that one too then... I just want something that can be easily mounted onto the defender cross bars, so presumed that the defender dedicated roof box would be the best bet? Current: MY22 P400e SE Prior: Discovery Sport HSE, Jaguar F-Type S, Discovery 3, RR Vogue |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
I believe it should fit as long as the distance between the rails is within the specs below
![]() Click image to enlarge 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
Does your roof box have quick release mounts or does the box have to be bolted to the roof rack? Current: MY22 P400e SE
Quick release. I think it’s called fast grip clamp.
Perfect, thanks! Current: MY22 P400e SE
