Home > Faults & Fixes (L663) > Defender wouldn't start |
simonbirt Member Since: 08 Jun 2021 Location: Wales Posts: 2 |
I have had this problem a few times now. On two occasions, I needed multiple attempts (3 or 4) before the car would start. On the most recent occasion, it wouldn't start after 7 or 8 attempts. Eventually I tried starting the car using remote start from the app, which worked immediately. Having started it once like this, it then started normally on the button.
It's something I plan to mention to the dealer in the new year - it's a pretty frustrating fault! |
27th Dec 2021 10:14am |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 |
Is it a diesel engined Defender and was it cold outside - less than 5C? Could be that you are not giving the glow plugs long enough to react before thinking it has failed to start. In normal weather mine starts instantly on pushing the button in the car, on a cold day it will do everything you describe and then I have to wait 10 secs or sometimes a little longer and then it starts. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
27th Dec 2021 11:24am |
Blacksheep Member Since: 10 Dec 2017 Location: Highlands Posts: 190 |
It could be the app?
I had a similar problem, deleted the app and no more problems! Leaving the app off for now. Might be worth a try… Time is precious, waste it wisely... Defender 90 D200 |
27th Dec 2021 12:03pm |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 163 |
Hello,
I had this problem once when I used the remote starter app, the remote car started, then when I opened the door it turned off and the button didn't start anymore ...... as suggested in other discussions, I locked the car with the remote control, waited five minutes, opened the car and it started normally. |
27th Dec 2021 4:15pm |
dizeeduckie Member Since: 10 Sep 2021 Location: London Posts: 55 |
Ahhh... this could definitely be it.
I had used the remote start but the app said there were connection problems. When I got to the car about 10 mins later, the engine wasn't running and it wouldn't start. But after locking the car for about 5 mins then trying again, it worked fine. And there's been no problem since. It did feel like a "computer says no" moment rather than a mechanical fault. |
31st Dec 2021 3:06pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1415 |
Same problem as me https://www.defender2.net/forum/topic80734.html Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
31st Dec 2021 7:58pm |
Yes, it's a D250, and yes, it was cool out - around 6C. However I did wait at least 10 secs after pressing the button and the car didn't start. This morning it's 2C and the car started within 2 secs on the first try. It's very odd. |
5th Jan 2022 8:41am |
