Home > Td5 > TD5 RPM Limits
LANDROVER
TD5 RPM Limits
Just out of interest what is the factory RPM limit on a TD5 in Low Range???
I thought on a defender TD5 selection of low changes throttle map and rpm limit.
Anyone got a reference from Land Rover?
I've never hit the limiter before but it was just interesting seeing people achieve this driving on YouTube.
Thank you for your information.
Post #935072 25th Dec 2021 11:31pm
miker
I don't think the rev limit changes when in low box, it's just a "spongier" throttle pedal map to reduce jerkiness.
Post #935074 25th Dec 2021 11:38pm
geobloke
As above. In Low box you still have the full RPM range, just you go much slower. The ECU dampens the response to the effort your foot puts in to reduce any jerkiness and deliver smooth power to the drivetrain.
Have you folks played around with the anti-stall on your TD5s? it is amazing how far it will go in 1st Low diff locked at idle Thumbs Up
Post #935128 26th Dec 2021 11:36am
LANDROVER
I've been told by a couple of people that the limit is lower in low range.
I just wondered if anyone had tested using nanocom or similar.
I've had mine remapped and now have the clutch pedal sensor disconnected but the antistall was quite clever but I've never relied on it.
Just an interest thing really as been playing with things just to see what it does.
Post #935134 26th Dec 2021 12:06pm
geobloke
Well all I can say with absolute certainty is my TD5 will go all the way when in low range, in all gears and in overdrive too Thumbs Up
Post #935135 26th Dec 2021 12:14pm
roel
No I don't Whistle
http://www.youtube.com/watch?v=qQrDcALvG0Q Roel
2003 90 Td5 (2009-now)
Post #935421 28th Dec 2021 5:22pm
geobloke
Nicely done Roel Thumbs Up
Post #935423 28th Dec 2021 5:29pm
lightning
Why on earth would you want to rev a TD5 to the limiter in low range?
Remind me never to buy a Defender you've previously owned!!
Post #935701 30th Dec 2021 9:32pm
bankz5152
Guess youve never driven in sand or extreme inclines Whistle
Rev limit is roughly 5k. Never hit the limit in 4th/5th high because thats madness.
I have hit the limit 1st - 4th on low. Not that hard to do
Anti stall is brilliant. 2nd low its greelane cruise control! Instagram @defender_ventures
Empire Tuning - Agent
Post #935747 31st Dec 2021 11:13am
miker
Done it a couple of times dragging trailers through mud, changing gear would rob all the momentum...
Also, occasionally hitting the rev limiter on a well maintained engine will do zero harm in the long run
Post #935749 31st Dec 2021 11:41am
lightning
l did think after posting the above, if you were using the Landy in competition you'd most likely be using all the RPM
l've never gone past 4,000 in mine, but in normal road use l guess you wouldn't need to. lt does go well 3,000-4,000 though. Seems to get smoother if anything
Post #935794 31st Dec 2021 6:10pm
Hufflepuff
While on the subject of rev limits - am I the only one here who finds it runs totally out of puff past 3000 rpm? I'm using the VDO td5 rev gauge, and at an indicated 2500rpm with the foot to the floor it starts smoking out the back, and its throwing clouds of black smoke out beyond 3000rpm, where it feels like acceleration has reduced anyway.
Its got an Alive remap on it, and after it was initially mapped the smoke was terrible so I visited them where they diagnosed 'low air flow', but we have no idea why.
The MAF was changed twice, using genuine VDO units and the problem persisted. In the end Alive reduced the fueling higher in the rev gauge which totally resolved the smoke issue below 2500rpm - but I've never been able to 'rev it out' if the mood takes me, which to be frank it rarely does these days anyway.
Two thoughts come to mind - the rev gauge isn't reading correctly - it reads about 2500rpm at a GPS 70mph in fifth gear with the 1.2 transfer box and 33" tyres on which sounds in the expected ballpark.
The second is - do I have a blockage somewhere in the intake? Its running the standard air box and pipework to the wing, and has the bigger intercooler on it. I guess I could undo the cover on the air box and take it for a spin to see if it makes any difference. 2005 Td5 90 XS
1989 V8 110 CSW
Post #935800 31st Dec 2021 7:20pm
bankz5152
Mine pulls hard till the top end. Even in 5th at 110 it wants to go more but i back off because of well fear Laughing
Could be a split intercooler, split hose, leak on the inlet. Black smoke plus poor revving sounds like a boost leak Instagram @defender_ventures
Post #935802 31st Dec 2021 7:33pm
lightning
l have to say that, my Alive remap didn't work, the Defender smoked like a tramp steamer under power and l had to have it reset by Land Rover.
l've now got an "economy" remap done by a local LR guy which is way better, obviously not as powerful, but no smoke and still a nice surge of power as the revs rise, spins up nicely to 4,000 rpm if needed, (which is rarely with me driving it!)
l think some remaps try to do too much, without other modifications you can easily get a Land Rover that puts out more smoke than an old Cortina.
Post #935819 31st Dec 2021 10:51pm
lightning
[quote="bankz5152"]Mine pulls hard till the top end. Even in 5th at 110 it wants to go more but i back off because of well fear Laughing
110mph in a Defender? Hells bells, l wouldn't want to try that, what
RPM is it doing at that speed?
Or do you mean 110 kmh?
Post #935820 31st Dec 2021 10:56pm
