Home > Maintenance & Modifications > Door Hinges |
Guinness Member Since: 04 Mar 2021 Location: Scotland Posts: 55 |
Hi All, I am after a set of door hinges as my doors are starting to sag quite dramatically. There have been many forum posts about these fancy security ones, but unfortunately, my budget is a constraint. Are aftermarket ones like these any good? :
https://www.lrparts.net/da1070w-full-front...shims.html OR Are OEM ones just that much better that I should fork out the extra money; (over 4 x the cost of after market) |
19th Dec 2021 12:23pm |
I went through the same decision process as you. Fell on a set of galvanised OEM hinges which I drilled for grease and painted with rattle can paint. Worked a treat and three years on they are still in A1 condition.
You can see the process from here https://www.defender2.net/forum/topic53859...;start=135 |
19th Dec 2021 1:21pm |
Currently I am swaying towards trying some well reviewed aftermarket ones, and if they fail in a year or so, then so be it, but i suppose its worth a try, i do like your idea geobloke of modifying the hinges to allow grease points!
19th Dec 2021 5:17pm |
mark1200 Member Since: 09 Oct 2011 Location: peterborough Posts: 72 |
I replaced my hinges with Bearmach ones they were about £25 and about £18 for a rattle can of the correct paint 3 years later and all is good. that original ones lasted 16 years so will see how long these last lol
20th Dec 2021 4:32pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
Second for bearmach ones!
20th Dec 2021 4:46pm |
You what they say... Every little helps and when it comes to Defender door hinges then being able to lubricate them can only be a good thing. I have just been back through my orders and these were Britpart hinges. Apart from a small bit of spikey galv they were well made and took paint well. Cannot complain... |
22nd Dec 2021 10:39am |
