Home > General & Technical (L663) > Offside (driver) wing mirror behaviour
P50WKB
United Kingdom 2009 Defender 90 Puma 2.4 CSW Santorini Black
My offside wing mirror occasionally appears to go dark, almost black, for no apparent reason. I have not managed to link the effect with temperature i.e. mirror heating pad, with sunlight i.e. some form of self dipping effect, with aircon settings or any other seemingly random events. There is no film on the glass. The mirror reverts to clear in its own time and the near side mirror does not exhibit the same phenomenon...............am I imagining this (although the wife has also commented on the same thing) ?
Post #933955 17th Dec 2021 8:50am
dizeeduckie
My wing mirrors are auto-dimming. Maybe there's a fault causing it to dim when it shouldn't.
When it happens do you notice about 1/4 inch around the mirror that isn't dark?
Post #933990 17th Dec 2021 12:06pm
Tim in Scotland
It’s the auto dimming which I think isn’t that clever (might be a bit dim!), mine occasionally do the same Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #933991 17th Dec 2021 12:07pm
P50WKB
Ah, thankyou both. I'm amazed as I didn't knowingly spec it specifically, although I do have Clearview. Yes, I do get the 1/4" clear band around the mirror when it "dims". At this time of year in North East Aberdeenshire the sun (!) is very low and I do tend to drive on the same roads so I am going to assume that it is indeed activated by the sun - I shall watch the near side mirror more closely as the season changes, but I do agree with Tim that the ratio of dimness over visibility is a bit excessive.
Post #933992 17th Dec 2021 12:33pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I noticed my OS mirror dimming and my non clearview interior mirror dimming this evening on the way home when the sun was very low and directly behind me. I'm sure I read somewhere that it is only the drivers side mirror that does this, the passenger side one is just a standard glass Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #934038 17th Dec 2021 7:17pm
J77
Yes LR penny pinching, only one mirror is auto dimming. 24MY 90 D250 HSE, Tasman Blue
Post #934040 17th Dec 2021 7:25pm
mse
Both mine do it, auto dip Mike
Post #934052 17th Dec 2021 8:35pm
J77
21MY cars only get the one auto dimming mirror. 24MY 90 D250 HSE, Tasman Blue
Post #934055 17th Dec 2021 8:43pm
Alicat
I will check mine, but I am sure both mirrors dip.
Post #934089 18th Dec 2021 10:23am
Alicat
I have been out this afternoon and both door mirrors are change to a dark green in certain lighting conditions. The LR has blind spot assist, I suspect the dimming function comes with the glass in these mirrors.
Post #934125 18th Dec 2021 4:47pm
mse
I had a 21 and both dipped?? Mike
Post #934129 18th Dec 2021 5:33pm
J77
Maybe spec related but my S only has the one.
EDIT - Seems all are only supposed to come with one
Post #934143 18th Dec 2021 6:57pm
Alicat
They must have run out of plain mirrors for the passenger side Rolling with laughter Rolling with laughter
Or Blind Spot Assist includes dimming on both mirrors. Thumbs Up
Post #934151 18th Dec 2021 7:47pm
Hairy Dan
Mine is a MY2022 SE with blind spot assist and I'm sure it's on the has the O/S one Confused Cheers Ian
Kielder 4x4 Safari
Post #934156 18th Dec 2021 8:15pm
hezor
Finland
I have a 22MY P400e SE and I only have the auto-dimming feature on the driver-side mirror. 22MY Defender 110 P400e SE w/ Off-Road Pack, Driver Assist Pack, Cold Climate Pack, Comfort & Convenience Pack + ClearSight Rear-View Mirror & 11.4" Infotainment Screen
Post #934352 20th Dec 2021 9:48am
