Home > Puma (Tdci) > Intermittent loss of power & speedo |
check earthing start with battery and work your way around
and of cores the ignition switch Last edited by dorsetsmith on 17th Dec 2021 3:17pm. Edited 2 times in total |
17th Dec 2021 2:44pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3741 |
I had similar but would just cut out, all dials off,
Sometimes it would restart almost straightaway, other times i would need to restart, It could do it once a week / month or 3 times on one 10 mile journey... hot / cold etc made no difference. It always restarted, but unnerving as your passing a truck on a motorway.. No codes on my code reader. I change the starter relay (under seat) still did it, then we changed the steering ignition key. All sorted |
17th Dec 2021 2:49pm |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 367 |
Got Ian at IRB to change the ignition key/switch in the week. Weird things were happening which made me doubt my sanity, but finally I had a witness when it failed to start three times in a row. The barrel was very well worn and the switch itself was loose in the housing - it’s held in place with two tiny self-tappers.
Ian always replaced the entire barrel (which needs new barrels in the drivers and rear doors) because it all wears together. The new barrel is much tighter and compared to the old one it’s night and day and I’m sure that the looseness of the lock barrel, with keys swinging around, caused the barrel and switch to wear even more. All good now. And my sanity is mostly restored. Dave Green Goddess - 1998 Defender 110 300tdi |
17th Dec 2021 4:08pm |
dommo_b Member Since: 17 Dec 2021 Location: Morzine Posts: 2 |
So I still have this intermittent problem, having checked as much earthing as possible and disconnected accessories such as a winch.
I noticed references to the previous owner having a gel battery in a dual battery setup. Is it possible the alternator setup was changed for a gel battery and might be causing problems now it has a conventional lead acid battery? |
28th Dec 2022 10:56am |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1960 |
Removing the alternator is not a big job and you will be able to see the part number label on the side of it to check if it’s a std landrover one.
However I expect it’s a standard one and as per above posts I would check out your ignition switch as the culprit. Lots of posts on here re the ignition switch, just do a search. |
28th Dec 2022 1:25pm |
