Home > In Car Electronics > Retrofit heated 2nd row seats? |
nick345345 Member Since: 05 Dec 2016 Location: Dunbar Posts: 71 |
Hi there,
After some complaints/feedback from backseat passengers, I'm considering how I could add heating elements to the 2nd row of seats in my 110 utility. I see that buying the heating pads is easy enough, but wondered if anyone had ever done this? I need to keep the ability to fold the seats forward, which seems like a challenge with the wiring. Thanks Nick |
16th Dec 2021 12:18pm |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 801 |
would of thought if the wiring ran down the seat base to the hinges then it should not be that hard to route the wiring. Think somebody on here with a white LS3 conversion, put rear heated seats in and put the switches on the trim panel in the rear compartment so second row users could turn them on/off from there. Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
16th Dec 2021 2:07pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3651 |
Pretty sure it was Andy: https://www.defender2.net/forum/topic65587.html
You’ll have to trawl through the thread though, but it’s a good un! |
16th Dec 2021 7:22pm |
Yep that’s the one, it’s close to the end from memory, or could of been on his previous build Searching for my first Defender...and started just as Covid hit, so talk about timing.
16th Dec 2021 7:43pm |
