![]() | Home > In Car Electronics (L663) > GMRS radio installation |
cyberhusky Member Since: 09 Feb 2021 Location: Luxembourg Posts: 276 ![]() ![]() |
Hello
is that the phone holder from Brodit? 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
umbertob mentions it is the A-Tach mount, it certainly looks similar to the Brodit mount, mine just came in the post this morning
![]() ![]() Click image to enlarge Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
I do have the other shorter Brodit mount for the Defender to hold my iPhone.
Now I'm not sure if I should get the short or long mount for the Midland CB Mic holder. The Mic is quiet heavy with the cable so I think the long mount is better. I just got the CB Radio this morning, ![]() Click image to enlarge 22MY Defender 110 (actual) | 10MY Freelander 2 (history) | 15MY Discovery Sport HSE (history) |
cyberhusky same CB as me and I find the smaller of the Brodit mounts fine
![]() ![]() Click image to enlarge ![]() Click image to enlarge Apologies for intruding on your thread umbertob ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
POPTOPP Member Since: 12 Mar 2022 Location: Virginia Posts: 11 ![]() ![]() |
Hey umbertob - would you shed some additional detail on where you ran the power cable and antenna wires? Where in the firewall did you pass these cables? And did you tap into a wiring harness to hardware power?
Thanks, Jeff |
bpjenks Member Since: 30 May 2020 Location: Altanta Posts: 2 ![]() ![]() ![]() |
I aminterested in the same thing: antennas through firewall. Any additional info/direction on this?
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
Some interesting setups, I have gone with a GME XRS 370 system,
The radio unit is fixed under the centre console, with the power cable routed through the passenger footwell panel to the fuse location behind the glove box, connected via a piggy back fuse to one of the 12v/aux fuse points.. Antennae is on a Tuff Ant mount which uses the passenger side hood/bonnet hinge on Aus/UK sided vehicles, the coax is fed under the top panel and through the large rubber grommet that the steering Column uses between the engine bay firewall.. it then runs through the driver side footwell side panel ![]() Click image to enlarge The mic magnetic mount is double side taped to a holdmyphone dash mount for the vehicle.. ![]() Click image to enlarge Very neat and no drilling, just the coax requires a hole punching through the grommet yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
