![]() | Home > Puma (Tdci) > Con”fuse”ion! |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
If you've got the connector off the switch, bridge the connector terminals with a small piece of wire or paperclip temporarily and see if the reverse lamp comes on. Or if you want to do further checks... With a multimeter in Volts mode. At the switch, between the Light Green with Purple and a ground (chassis) should be 12V ignition. Green with Brown is the output from the switch to the lamp. At the lamp, between the White (RHD) or Grey (LHD) wire and Black wire should be 12V when ignition on and in reverse. HOWEVER, as in my post above, you can see 12V across here but there's no current able to pass through the switch. For continuity check.. With multimeter in Ohms mode or continuity buzzer. From switch Green/Brown to lamp White (RHD) or Grey (LHD), should be continuity/low Ohms. From lamp Black to chassis should be continuity/low Ohms. However you would have other lamp issues on the same side if this ground was faulty. ![]() ![]() |
![]() Click image to enlarge Thanks to Will@LRW ![]() ![]() ![]() |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Great stuff Martin, very much appreciated. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3537 ![]() ![]() ![]() |
Most items covered above..
I guess you have already confirmed that you do have brake lights when the ignition is on. Same connection on ignition switch, but then I guess you have far more problems than just non operating reverse lamp. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
0V at the switch connectors.... is that checking between the 2 connections, ore one connection of the connector at a time to a good earth on the body/chassis or negative battery terminal? Can you also remove fuse F10 and see if you have 12V on one side of the fuse contacts inside the fuse box while the ignition is on (no need to be in reverse gear)? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks Darren. Yep, everything else is OK, just the reversing lamp.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Make up a test light with a bulb holder in place and two needles solder on the tails of the wires with the fuse and try the wiggle test on the wire and if the light goes dim/out you’ve found your fault. I’d look at where it goes In and out of chassis rails and up the side of the bulkhead and down.
Check the actual fuse holder too as the quality of them is well 💩 You might have a ground and a 12v but the break corrosion can’t carry the load. ![]() Click image to enlarge |
