![]() | Home > In Car Electronics > Heated Screen Replacement |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
I'd try cleaning the insulation off the remaining tabs and soldering a new wire and connector on, test the screen and if its OK then re insulate the tabs.
HTH Keith |
www.ebay.co.uk/itm/165147939784?mkevt=1&am...db38b45f68
Loctite LT 1831738 Circuit Repair J-B Weld 8297 High Heat Temperature Resistant Epoxy Putty Stick, Machine Gray, 2oz glue left one the screen and use circuit repair right hand one remove insulation solder new male spade tab on or short places wire 6mm with male spade |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 908 ![]() ![]() ![]() |
Cheers chaps
![]() I’ll attack it next week. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
