Home > Technical > Stainless Steel Brake Pistons
Page 2 of 3 <123>
ksv
Russia 2007 Defender 110 Puma 2.4 SW Keswick Green
Looked in my notebook, it was five years ago and about 100000 km. Of course they only pack, I think.
Post #932095 1st Dec 2021 7:34pm
Oldowner
I’ve had Britpart stainless pistons for years they are excellent. One defender is in the sea most days, pistons are still fine.
Post #932108 1st Dec 2021 9:14pm
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
I bought and installed on my 90
- Front stainless pistons (46mm) from Island 4x4 c/w seals AEU2539G as a kit
- Rear stainless pistons (think 41mm) from LOF as a kit
(LOF did not have front and rears in stock at the time )
I found no difference in the quality of those from LOF and set bought from Island 4x4
I also bought spare set of seals for both front and back calipers - luckily I did cause on installing one of the seals I did ever so slightly deform the seal retaining rings
make sure buy some hose clamps - small ones - if you have not got any
All been installed approx 2 years with no issues what so ever. The original pistons they replaced were generally not too bad, I had one on the rear and one on the front which I feel would have damaged the seals when pushed back in so glad I did change them at 5 years old (I live by the sea)
Post #932137 2nd Dec 2021 8:54am
dorsetsmith
Castrol Red Rubber Grease Brake Caliper Fluid Rebuild
and this very use fall for replacing retuning ring with out having to split the calipers https://fourby.co.uk/Land-Rover-Series-Def...build-Tool
Post #932164 2nd Dec 2021 12:46pm
hank
I also fitted britpart ones - good quality > 110 XS Double Cab
Post #932169 2nd Dec 2021 1:15pm
Iktank
I concur very handy to have - used exactly the same and very useful for seating the seal retaining rings evenly
Post #932170 2nd Dec 2021 1:26pm
geobloke
Sorry I missed this. But brilliant tool Thumbs Up Thumbs Up I was rather taken by Britannica's caliper tool as well.
A New Years present I think... Rolling Eyes
Post #934924 24th Dec 2021 12:10pm
geobloke
Excellent post. Many thanks Thumbs Up This will now be a New Year project. Thumbs Up
Did you split the callipers or keep them in one piece?
Post #934926 24th Dec 2021 12:17pm
hank
Keep in one piece. Just enough room to do one piston at a time > 110 XS Double Cab
Post #934931 24th Dec 2021 12:45pm
Iktank
Yup keep in one piece most definitely
Have a lovely Christmas all
Post #934936 24th Dec 2021 2:04pm
geobloke
Excellent. Many thanks both Thumbs Up Thumbs Up
Merry Christmas to you both Smile
Post #934939 24th Dec 2021 2:18pm
There are many who say that it is unwise ever to split the calipers, although it is hard to see why this should be. It is certainly not easy to find the correct replacement gallery seals if you split them.
It isn't really necessary to split them.
Post #934963 24th Dec 2021 5:28pm
donmacn
There was a time…. the only time I’ve split a caliper was on an original Mini, fitting Cooper ‘S’ brake discs and callipers… but it was a Mini, and it was 1989..
At that point the kit came with the pistons, piston seals/retainers, and the gallery seals.
I’ll be doing a complete replacement/rebuild front axle on the Defender next year some time so I’m just following this thread to know more about the caliper options. I’d heard of Big Red previously and thought they’d be worth a look. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #934998 24th Dec 2021 9:33pm
Grenadier
Merry Christmas one and all. As part of ongoing repairs/upgrades, I’ve got the brakes to do. I’ve bought new braided lines, new pads, will be getting new discs etc. The piston upgrade is something I’m also keen to do, so this is all very useful info. But can I ask, just to know, is this modification just about future-proofing the brakes (rust prevention, wear and tear etc) or does it also actually improve braking? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #935232 27th Dec 2021 8:15am
Iktank
More so future proof, my defender was 6 years old when I changed mine and I live by the sea
They would not have lasted another year as two of the pistons were showing significant rusting that would damage pistons seals when pushed in with new pads.
It is worth doing but get some spare seal kit as you will buckle at least 1 dust/retaining ring (well i did Very Happy )
Post #935234 27th Dec 2021 8:32am
Page 2 of 3 <123>
