![]() | Home > Off Topic > Anyone else been Storm Arwened? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
That’s good news 👍🏻 Chillin In The Backwoods🇬🇧🇺🇸
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3564 ![]() ![]() ![]() |
That's really good news, Bluest
![]() You are correct, our reliance on the electrickery is all and encompassing. I have been told that I need to be more positive in my outlook (I am not the person who has with his family, been freezing their bits off in the dark for the last five or so days). Just think of all that electricity and money you have saved ![]() Bet you won't be able to buy a Generator now till Easter ![]() Glad it's all sorted ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
Being a naturally frugal type, the 4 days saving on gas hadn’t escaped my notice, especially as I’m on the expensive tariff after Avro went bust.
125A Changeover Switch - Single Phase
![]() Click image to enlarge so you can have DNO supply or generator ( brake before make both ways ) and earthing rod for standby use only 2P+E INLET 250V for outside wall sized to you power needs up to 125 amps but as most houses have 100 amp headers and 90 amp fuse ![]() installed post DNO power meter and before your dis-board If you have split phase supply i.e. 2 phases Neutral and earth 3phane set up will cuver this |
