![]() | Home > Maintenance & Modifications > 2007 Defender 90 Red Booster |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Have you taken a look at the LOF Clutch system? A game changer and your knees will thank you for it….
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3698 ![]() ![]() ![]() |
Agreed. LOF master cylinder and power spring fitted to mine and it is lighter than the wife’s mini. Much cheaper option than red booster as well.
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 ![]() ![]() |
Having driven a defender with a red booster, I thought it was horrible and hated it. Yes the pedal is very light but there was no feel at all and wasnt a nice feeling at all. And then you have to look at the price because they aren’t cheap at all
I have a LOF clutch spring at the moment and that works well, if I was doing it now I’d be buying the willwood master cylinder |
LandyHelp Member Since: 09 Aug 2020 Location: caribbean Posts: 13 ![]() |
Excellent all. Thank you so much. I have contacted LOF and see what they say. Can any garage fit? Hoping it isnt complicated.
Luke is excellent, as is his gear. Any competent mechanic can install the LOF gear, even a DIY guy like me
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
My Td5 clutch with spring and slave cylinder is too light for me, so have got to sort, but shows how light it can be made.
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
Just listed, bargain.
https://www.defender2.net/forum/topic81368.html |
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
I have had a Red booster fitted on my TD5 and although it feels like the clutch needs bleeding I find it easy to drive and it might put off a potential thief thinking the clutch is broken
