![]() | Home > Puma (Tdci) > 2.4 oil feed pipe replacement - advice please |
driver Member Since: 02 Aug 2009 Location: bude , cornwall Posts: 206 ![]() ![]() ![]() |
I have just changed the turbo on mine and had the same dilemma, in the end I left it alone as it was not leaking and seemed in good condition, once you remove the turbo you can see where it goes in to the block but look very fiddly to do.
no need to remove the dipstick tube either, Things I did, Prime the turbo with fresh oil, Change the engine oil and filter, Fit a new copper washer to the oil feed banjo bolt, Fit a new gasket to the oil return pipe, fit new exhaust gasket, Hope this helps |
yorkshirelandy Member Since: 26 May 2015 Location: East Yorkshire Posts: 53 ![]() ![]() ![]() |
Thanks for the reply Driver, good to hear I’m not the only one!
I’ve started the rebuild today and have done exactly the same as you with new washers, gaskets etc. Doing this job in the middle of winter on my gravel drive has not been pleasant ![]() |
