Home > V8 > 110 County Snorkel Options for a 3.5 V8 w/carbs?
nolift911
United States 1995 Defender 110 V8 Petrol CSW Alveston Red
Any out there - thanks.
Jeff
Post #931009 24th Nov 2021 5:17pm
markb110
Mantec used to make one as I had one from them when they were originally running the business out of their garage at home.
The main pipe went down through the wing top then a rubber hose that was looped to enter the air box between the carbs.
Not sure who is doing an equivalent, or alternatively the Southdown version from Terrafirma though can’t confirm if the rubber hose is long enough for where you need to route it.
Good luck
Thumbs Up
Post #931014 24th Nov 2021 5:55pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
Various types, e.g. a posh one that goes through the wing vent and doesn't require cutting holes in the wing - but will need some bespoke pipework to attach to you air filter housing.
https://www.nakatanenga.de/en/vehicle-equi...r-housing.
However I'm guessing that the carb V8 doesn't have an air intake in the wing like the Turbo diesels that followed? If so you'll have to do some wing butchering to make an off-the-shelf RAI fit.
https://www.johncraddockltd.co.uk/da3025-s...tment.html
series 3/early Ninety/One Ten type... https://www.roversnorth.com/parts/rna2002_...y_defender JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #931084 25th Nov 2021 10:08am
camelman
Post #931090 25th Nov 2021 11:30am
Lodelaner
Looks same as the one in the Craddocks link but £50 more expensive. JB
Post #931091 25th Nov 2021 11:36am
camelman
Have you ever bought anything from craddocks? Whistle
Post #931093 25th Nov 2021 11:41am
Lodelaner
Yes. Variable experience over the years as with eBay. JB
Post #931095 25th Nov 2021 11:43am
nolift911
Thanks gents - says up to 94? Wonder why not 95 -
Also I have an external cage and says not compatible - sorry left that detail out.
I thought there was one floating around the internet for a V8, 3.5 and carbs with a cage...could be wrong?
Jeff
Post #931103 25th Nov 2021 1:29pm
jonny
If you have a cage, I think you may struggle to get one to fit off the shelf.
I'd probably go to my local exhaust fabricator and get them to mandrel bend a piece of 2 1/5 or 3" pipe with a kink at the bottom to match the bulkhead / windscreen join and add a couple of tabs so that it can be mounted to the cage with P Clips.
Add another hole for it to go through the wing top in front of where the cage likely goes through, bit of flexi tubing at one end to connect to the airbox and a safari style snorkel top from ebay and you likely have something that works as well for sub $100...
Post #931104 25th Nov 2021 1:36pm
camelman
Jeff
It's not a huge job to fit a wing type snorkel if you've got a cage, I did it on my 110 hardtop.
Just need to extend the wing hole a bit and make a blanking plate up.
Post #931108 25th Nov 2021 1:50pm
camelman
Southdown also do a V8 version that is compatible with a cage:
https://www.southdown4x4.co.uk/Southdown%2...norkel.htm
You do need to cut a hole in your wing however.
Post #931110 25th Nov 2021 1:52pm
nolift911
Jeff
Thanks! This might work as I don't have a hole yet - does the side hole have to be in a specific spot...? Or with the cage I can move a few inches for clearance and still have it tight?
Post #931279 26th Nov 2021 4:22pm
