Home > Td5 > Rear wiper not working
nobbyclark
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
The rear wiper has stopped wiping on my 110 TD5. I noticed it was getting slower and slower in operation. I thought it might be because it needed some sort of lubrication but WD40 and grease haven't made a difference. I've checked the fuse and it's OK. Dead motor?
Post #930702 22nd Nov 2021 5:19pm
geobloke
Have you checked the contacts are clean, especially the earth and that there is 12v at the wiper motor. If that lot is A-OK then it is time to open the motor up and have a look at what is going on inside. Could be just that the motor's brushes are grimy or the spindle is bunged up with rust.
Post #930713 22nd Nov 2021 5:56pm
landy andy
Check the arm isn’t against the spare wheel. Check the relay under the dash, also check the earth to the door, as you know you have a live supply. If me I’d stick 12V direct to the motor and see what happens. That way you know if it is supply, or motor.
Post #930735 22nd Nov 2021 7:37pm
dorsetsmith
Post #930740 22nd Nov 2021 8:18pm
bodstruck
The motor was duff on mine when I had the same problem. One of the magnets had come away and water had played a bit of havoc in there as well
Had to get a new one in the end.
Post #930742 22nd Nov 2021 8:36pm
nobbyclark
Thanks for all the replies; yet another project for the weekend.
Does anyone know if a non-functioning rear wiper is an MOT fail? I've looked at the Government MOT site and it mentions forward facing windscreen and wipers but nothing about the rear. Various other links suggest it is OK but I obviously want it fixed either way.
Post #930765 23rd Nov 2021 8:26am
rallysteve
Worth a check of the wires in the corrugated rubber duct which runs between the body and the rear door. The cables often break due to fatigue where they bend much like the side doors.
Post #930790 23rd Nov 2021 11:00am
nobbyclark
Thanks for that; someone responded in the central locking thread about a similar problem so will definitely check.
Post #930792 23rd Nov 2021 11:26am
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
A non working rear wiper is not an MOT fail.
Post #930920 24th Nov 2021 7:35am
nobbyclark
Thanks for confirming; fingers crossed for Monday!
Post #930934 24th Nov 2021 9:13am
