![]() | Home > Off Topic > Dent removal |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
Can you get a bottle jack and a couple of pieces of wood in there. Maybe a slow approach to putting pressure on the inside of the dent.
It might pop back without the need to hit it on the inside |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 ![]() ![]() ![]() |
Hi,
I forgot to mention, it’s double skinned because it circulates air for a secondary burn so no access from inside. It is quite thin gauge stainless. Maybe around 1.5mm 2002 110 td5 |
Glass moving sucker and pull gently on the outside, deduct relevant amount from child's allowance / trust fund etc...
https://www.amazon.co.uk/IMT-Suction-Grani...4&th=1 |
Thanks. I might have one of those laying around somewhere, as you do!
To be fair on my kid, he was probably more upset with himself than I was. He knows how much I love my fire pit 2002 110 td5 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
With it being stainless, it’s likely there’ll alway be evidence of a dent there, it doesn’t like being worked. As mentioned, I’d try sucker. Can you find a way to hold it so can put some force into it? 2007 110 TDCi Station Wagon XS
I’ll see what I can rig up. I’ll try putting something heavy inside it. I’ll let you know how I get on 👍 2002 110 td5
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3655 ![]() ![]() ![]() |
if you struggle with a sucker but you have a hot glue gun, you could try to glue something to the outside to pull it with and then use a hair drier to get the glue back off. DEFENDER 90 TDCI XS,
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2135 ![]() ![]() |
Perhaps having a chat with a local car bodyshop, they will be very used to pulling dents, albeit mostly on mild steel and then filling and painting. However they will have a range of suction pullers and I expect you will need a few strategically placed pullers that are simultaneously pulled to ensure the minimum of panel creasing is visible once the process is completed.
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
if the sucker doesn't work you might have to cut a hole in the inner skin to try the jack idea mentioned and then pop rivet a repair piece over the hole.im assuming a patch in the inner skin wont be noticed to much. |
Thanks chaps. I’ll have a quick go with the sucker, but I’ll probably end up taking it somewhere for a professional to have a go at it. 2002 110 td5
I’d call the sucker technique a success in this instance. If the little creases left at either side still bug me, I might use a glue gun for a little localised tweaking.
![]() Click image to enlarge 2002 110 td5 |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
I used to have a dent removal kit which involved something similar, you glued loads of tags onto the damaged area and then attached them to a sliding hammer, it worked reasonably well on a double skinned section of a truck cab Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
![]() I hope everyone is well and your land rovers make you happy |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
If you can pour a little fuel in between the skins and light it, the dent should pop out….
![]() And I’m only suggesting a little fuel… being teaspoon amounts (5ml) Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
