![]() | Home > Puma (Tdci) > original springs condition |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4760 ![]() ![]() |
My 1992 110 200 tdi is still on it's original springs so there is no reason why the springs in your vehicle should need changing. 1982 88" 2.25 diesel
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 ![]() ![]() |
You've done well then, springs naturally sag over time even when loaded normally.
Our 2006 90 had lost nearly 2" on its as built ride height by the age of 10 without any loading modifications to get it to that point. Try this site.... http://red90.ca/rovers/springinfo.html |
The original shocks were replaced last year......I suppose it all depends on how much load the vehicle carries or heavy towing it does. 1982 88" 2.25 diesel
Bundy Member Since: 21 Sep 2020 Location: Cheshire Posts: 98 ![]() ![]() |
I recently replaced the suspension on my 2009 110 and the fronts had sagged a good inch or so.
Helpful measuring info on Gwyn Lewis website... https://gwynlewis4x4.co.uk/wp-content/uplo...rments.pdf Cheers Al |
orzowei Member Since: 10 Mar 2021 Location: toscana Posts: 14 ![]() ![]() ![]() |
grazie mille!!!
