Home > In Car Electronics > Quick question about led bulbs for interior courtesy lights. |
ChrisCSL Member Since: 10 Aug 2019 Location: Berks Posts: 186 |
These are the LED interior bulbs I use in my puma. Nice light. Kit includes two bulbs.
https://houseofurban.co.uk/collections/lan...t-bulb-kit Chris |
15th Nov 2021 1:15pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3384 |
Or you can go the cheapo ebay route.
I got a pair for £3 and they work fine just search C5W LED |
15th Nov 2021 1:39pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Any idea what length you ordered camelman and whether they are then dimmable as per the theatre dimming on later vehicles?
I guess CANbus compatible should help, but not sure there.... |
15th Nov 2021 3:50pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2092 |
Food for thought if you have a Puma from 2012.
From remotekey on failures of the ALM ECU. “A problem with Defender 2012 onwards with the black unit fitted is they don’t function with LED interior lighting, we have had problems with the interior light circuit failing when LED’s are used” By which they mean the interior light circuit in the ALM ECU failed due to the use of LED’s ! Last paragraph before the pics at the bottom of the page https://remotekey.co.uk/land-rover-keys-re...larm-ecus/ |
15th Nov 2021 9:56pm |
lakelander Member Since: 07 Jan 2017 Location: Cumbria Posts: 100 |
This is new news for me, and is potentially alarming ! ( sorry! )
My Puma is a Dec 2012 build ( reg march 2013 ). It is still on its original battery and battery , alarm, immobilized and fobs are all performing well. It has led bulbs in the interior lights which also work fine ( although the front interior does flicker when rear door is open ? Bad earth? ) Having read the link to remotekey.com I will need to check out the colour and part number of my alarm control box. Had anybody experienced these problems of the alarm control box failing when the vehicle battery is old and dying? It will be cheaper and less problematic to change the battery than change the alarm control box |
16th Nov 2021 9:34am |
Can't remember off the top of my head, I just bought the same length as currently in there. They do dim after closing the doors (in my TD5), I've got the MUDSTUFF complete replacement units in the Puma |
16th Nov 2021 10:50am |
Re ALM ECU failing due to low battery causing brownout, unfortunately YES . See this topic and my posts https://www.defender2.net/forum/topic80048.html Yours will likely be an ALM ECU (black) and be a CH serial number. So keep the battery well charged. . |
16th Nov 2021 12:29pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1083 |
Are you sure? Switches go to the ALM, ALM controls both lamp's earths (in the auto/dim position) in parallel. Also all door switches but the driver's door are wired in parallel and the ALM can't tell which one is which. So, if only one lamp flickers, something's wrong with the lamp, but it should flicker if any of the doors is open. On the other hand, if only one door causes a flickering lamp, the door switch may be bad, but then both lamps should flicker. |
16th Nov 2021 7:59pm |
Cheapo LED lights are known to cause issues. I can't comment on the alarm/interior light issue. It's not uncommon that cheap headlights ruin radio reception and can cause other issues so why not.
Best to by from reputable LR suppliers and treat eBay with caution. |
17th Nov 2021 11:56am |
More info which might be interesting:
https://www.defender2.net/forum/topic33693...ight+issue |
17th Nov 2021 12:04pm |
Thanks for advice Silly question I know - but where is the Alarm ECU located? Can't find it !! |
18th Nov 2021 2:35pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 815 |
I have used these
https://www.ebay.co.uk/itm/2x-PURE-WHITE-L...635-2958-0 No problems, no flicker just clean white light. Jim |
18th Nov 2021 2:46pm |
To check remove drivers footwell speaker and look upwards under your dash with your head just above the peddles. If the unit is black it’s the ALM not a 10as which is green . If serial number beginning with CH it’s first gen ALM ECU, if DH it's second gen ALM ECU |
18th Nov 2021 10:51pm |
Thanks
19th Nov 2021 10:11am |
