![]() | Home > Puma (Tdci) > 2.4 Puma wholesale electrical gremlins |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3657 ![]() ![]() ![]() |
could all be related to a poor earth connection, check all of your earth connections or create some new ones. DEFENDER 90 TDCI XS,
Kretchman Member Since: 07 Sep 2021 Location: Auckland Posts: 5 ![]() ![]() ![]() |
Won't write a poor earth out of the equation, but I tracked the problem to this:
Issue started when I wound the window down. Searched the wiring diagram, and there was a common element that connected all of the above ancillaries. The 5a fuse no. 15 (on a 2.4L) seems to do the same thing as fuse 4P on the later 2.2L's and is the ignition feed for the following:
Window lift relay R143 Window heater front D247 Heated rear screen switch S120 Headlight relay R123 I checked fuse 15 and it was blown. Replaced it and success. Then checked the window switches and the driver side didn't work but passenger did. Swapped them over and fault went to the passenger side. So I'm guessing dead drivers window switch shorted and blew fuse fuse 15 causing my issue. Not sure why the washer/wipers and other ancillaries stopped working too, as on my wiring diagram they aren't fed from fuse 15 (but maybe I have an outdated diagram). |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 ![]() ![]() ![]() |
well done, for checking wiring disgrams, im useless with them
congrats on solving the issue DEFENDER 90 TDCI XS,
Sussex110 Member Since: 18 Jun 2021 Location: Sussex Posts: 23 ![]() ![]() ![]() |
Just wanted to add to this thread as I had the same issue over the weekend on my 2.4 Puma after fitting a new battery.
Changed F15 fuse, checked all connections to the new battery and still had the issue of no gauges or dash lights. Ended up disconnecting the battery for an hour, problem fixed! Hope this helps someone in the future. |
